Question about Fisher Paykel EcoSmart GWL15
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
Seems to be common problem ,will check pump etc .but how do you drain washer ,its full from wash cycle?
  • jperry599 Feb 22, 2009
    I have had this washer for 2 1/2 weeks and no problem until today.
    It fills, agitates, but won't rinse or spin. It beeps every second and one wash, one rinse and the spin light are on.
    Scholar:
  • 99 Answers
This is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Posted on Feb 07, 2009
How do I see what is causing my Fisher & Paykel EcoSmart washer to leak water?
If it is leaking when draining this would point to the main seal of the WATER PUMP. (Quite common for older machines.)
The pump can be easily removed by leaning the machine backwards, remove wires and see picture. NOTE: about half a litre of water will gush out so it is best to take machine outdoors. Go to a recycling centre or online auction for a replacement. They can be fiddly to replace.
Jul 20, 2014 | Fisher Paykel EcoSmart GWL15
Pump squeals when emptying water at start of rinse cycle
Possible there is dirt in the drain which seems to clog on the drain pump /valve and so when the drain cycle is activated the pressure makes the noise on the pump.
Check for tips to remove the Pump;
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 19, 2011 | Fisher Paykel EcoSmart GWL15
My washer goes through the 3 wash cycles but starts beeping and the water won't empty as it reaches the rinse cycle. what can i do?
Possible that the drain is clogged or the drain valve/pump is struck or is not activated by the program controller. If on checking there is voltage on the valve/pump without action then this can be faulty.
remove and check
Dec 22, 2010 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Water will not drain before rinse
unplug from wall slide washer forward, tip back disconnect connector and gnd wire press lever and twist pump ccw it will unsnap and come down. use oil drain pain to catch water check for blockages. (note: pump 110vac and can be tested out of washer)
Mar 21, 2010 | Fisher Paykel EcoSmart GWL15
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
The washer wont drain
Check clear filter //pump
Sep 29, 2009 | Fisher Paykel EcoSmart GWL15
Problem draining &spinning
Get the strings coins and sand out the pump and retry
Dec 17, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
743 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
