Question about Yamaha RX-V757 Receiver
Yamaha RX-V757 No Left Channel Output - Video Sources Only
Yamaha not delivering left channel output for VCR and DVD sources - fine for audio sources (CD).  Have worked through setup several times but cannot determine problem.  Tried VCR that I know is working.  Is there a fuse on input side of amp, or am I looking at some type of logic failure?  Will be the second Yamaha to fail me if so.  Worth buying a repair manual?
  • mjb9 Feb 07, 2009
    Had tried that - reversing cable didn't change situation.  Still only one channel out to speakers.  Aggravating in the extreme as CD plays both channels; only video sources have one channel output.
    Thanks dthomas in any event.
  • mjb9 Feb 07, 2009
    Wait a minute - yes, it is a bad cable!!!  Thanks dthomas!
  • 4 Answers
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Posted on Feb 07, 2009
  • D Thomas
    D Thomas Feb 07, 2009
    No problem - I'm glad I could help! Until next time -
    Peace In Your Heart, Mind and Family,
Yamaha NS-AP6500M/NS-AP6500E One speaker works when all are tested but does not whit media sources
that would depend on the channel.
I've seen people complaining that one channel was blown while operating in 5.1 mode, but then in 6.1 suddenly and magically was just a speaker connected to the wrong output on the avr... start with checking that.
if that is not the issue, than it is possible that the input in just stereo and the output for the dsp is not set to copy stereo to all channels...but this should be noticeable in more speakers...rather all except left and right frontals.
Feb 23, 2016 | Yamaha Audio Players & Recorders
My left channel is out on Yamaha RX-V557 what do I need to fix it
Check the speaker of the left channel first. If found OK, check and replace damaged component/s at its audio output [Left] channel. Refer its circuit diagram. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Aug 10, 2015 | Yamaha Audio Players & Recorders
Receiver turns on for 2 seconds and then turns off itself, tried on different power sources but problem persists.
Short circuited component/s at its audio output stage circuit. Contact any service technician to get it repaired. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jul 18, 2015 | Yamaha RX-V757 Receiver
Bad left channel on home cinema system
The output transistor is probally shot,
Dec 04, 2012 | Yamaha RX-V496 Receiver
Yamaha rx-v663 is there a firmware update to get hdmi 1.4a support ?
Unfortunatly there is not any firmware to upgrade your unit to a higher HDMI format. There is a firmware though that corrects the following symptoms.
1. In case of playback of some DTS-HD Master Audio stream, pop noise may be generated.
2. Test tone may not be output under specific YPAO condition.
3. When test tone is output from presence channel, surround R channel is simultaneously output when speaker settings are PRESENCE SP "EXIST" and SWFR "NONE".
4. Multi channel input setting will be reset after power off the unit, in case of setting "INPUT CH" to "8CH" and "FRONT" to "VCR" or "V-AUX".
Apr 10, 2012 | Yamaha RX-V663 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
I've lost all digital sound to my reciever.
Get into the cable box menu and look for audio settings, chances are your digital output from the cable box is off. If you still can't get audio, reply with your Cable Box Make & Model and I can help you further. Hope this helps
May 25, 2009 | Yamaha RX-V757 Receiver
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
May 21, 2009 | Yamaha RX-V596 Receiver
RX-V902 TV/DBS source coming through all other sources...
This could be as simple as having input and output line audio reversed. Please check all sources for proper connection. You can do this at the receiver too, but not both receiver and sources.....accordianman
Oct 31, 2007 | Yamaha R-V902 Receiver
Yamaha RX-V757 Receiver Logo
197 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
