I have a Porter Cable Model 333 5" sander The lower bearing is seized and I can't get the lower bear off. It seems to be pressed on.
I followed the suggestion and gently pried up on both side with a couple of screw drivers. After a few frustrating minutes it popped off.
There is a screw holding the pulley on remove it and what I would do is take 2 screwdrivers and gently pry up from either side, The bearing is generally a loose press fit. You might want to take a look at a breakdown at Dewaltservicenet.com and type in your model number so you can see what it looks like. Good luck
