Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
Whirlpool side by side refrigerator light will not work. the lights in the freezer side work. ensured new light bulb works, took out door switch and it seems good, have power to switch what is left?There is a irratic clicking sound coming from the lower right bottom of the fridge only when the fridge side is opened. The light does not come on and the LEDs on the controls do not light up either. The clicking goes away when the door switch is pressed. The freezer side light works fine. The fridge/freezer are cooling fine. Sounds like a bad relay???? Any help would be great!
Thanks!
  • Travis Reinert Feb 07, 2009
    Thank you Peyton. I have ordered the replacement board and will change out.
  • air_randy Feb 27, 2009
    I have the same problem and I gather from tons of information on this matter it has to be the main control module next to the compressor. I'm going to go ahead and replace it. air_randy@yahoo.com
  • 410 Answers
Your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Posted on Feb 07, 2009
Refrigerator not working, lights arem out. The freezer is working lights are on.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Lights are not working in the refridgerator. Freezer lights work. Replaced switch,still no lights
did you replace the bulb? what you can also check, and the likely cause will be the socket itself. unplug the fridge from the wall outlet, remove the bulb from the socket. you will see 2 copper tabs, on e on side, one at bottom of socket, bend these slightly toward you, to ensure they contact bulb. replace bulb, plug back in and check. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
No air flow to refrigerator section
hi thanks for the question yes lots of times i would check the fan motor in freezer you should be able to hear the fan going with the freezer door open if not replace the fan motor in freezer and also check for frost build up in freezer thanks the appliance doc
Aug 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gs5shaxnb02 Ice maker
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
http://www.whirlpool.com/custserv/index.jsp
Jul 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
Jan 01, 2008 | Whirlpool ED2FHEXN Side by Side...
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
448 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
