Question about GE 2-9450C Corded Phone
GE 4 line phone model 2-9450 Wont get a Dial tone
I have tried all the suggestions posted here, found all manuals. But I still cant seem to get any of my 5 phones working. They all were disconnected while we moved our new location. And when I went to hook them up. They cant get past this two tone beep every time I try to set them up. The only thing I think could be wrong is that this new location only has one phone line. Is this the problem? Do these phones need a minimum of two lines?
  • 1 more comment
  • rupenz72 Feb 15, 2009
    Dear Netpak
    I have a similar problem, what seems to have happened is that the STATION-ID of the phone has been Reset due to Low-Battery. But, even after changing the battery when I try to follow the manual instructions on setting up the Station-Id I am unable to do so.
    Pressing any button gives a 2-tone beep. I hope someone has a solution for this.
  • dowebite Mar 12, 2009
    I have the same problem. did anyone get it to work?
  • MAMCO May 07, 2009
    Can't get a dial tone, same green/red flash on the intercom button, using one line- dont have a manual either someone should upload
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
  • 50 Answers
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
Posted on May 28, 2009
SOURCE: When I get ready to dial, phone beeps 3 times
You must have an answering service from your phone company, and probably don't know about it. Try dialing your own # and wait for the prompts.
Posted on Aug 10, 2009
popsgifts
  • 160 Answers
SOURCE: Has new battery, but no dial-tone,
Replacing the battery reset the phone to the factory defaults, which means you'll have to restore the connection to the base in Menu-Setup
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 19, 2010
  • 4 Answers
SOURCE: phone beeps before dial tone
usually this means you have voicemail...listen to the messages and delete them and the beeps should go away...
Posted on Aug 20, 2010
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
Can get dial tone but cant dial out
If you haven't tried it yet, reverse the two incoming line wires. Some phones have to be a particular polarity. I have had a case where things were working, then a lineman somewhere reversed the connections at a pedestal someplace and my phone would not dial.
Jul 25, 2009 | GE 5.8 GHz Cordless CID Speaker Phone X 2...
Outgoing call does not connect when I dial the number
depends on the telephone exchange . Suggest switching to Tone signalling . MTDF - https://en.wikipedia.org/wiki/Pulse_dialing
Old technology- Pulse or Decadic Signalling - the line is broken by a relay contact or if even older a rotary dial manual switch contact - Dial a 9 you would break the line connection 9 times and send nine pulses.
Tone sends two frequency tones that encode the number that you selected and is a much faster dialing system and more modern method.
Oct 16, 2017 | GE 27906 Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
No dial tone.
make sure the line is connected right try replacing the cord or maby the lines in your area are down out of service this happens
Mar 08, 2009 | Uniden Cordless Phone
GE Spacemaker Kitchen Phone/Radio/Answering Machine Model 26976 GE 1
I would pack it and send it to GE for repair replacement as defective
Mar 23, 2017 | GE Spacemaker 26976 Cordless Phone
GE 5.8 ghz cordless phone
the menu will take you to registering the hand sets to the base unit
by deleting incoming calls you have disconnected from the line
follow the instructions in the user manual to get reconnected
if you do not have the user manual , go google and type in --user manual for ge ( model ) cordless phone --and down load the pdf version
May 25, 2017 | GE 27957GE1 Phone
GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Mar 19, 2008 | Thomson 26943GE1 Cordless Expansion...
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Lands Phones Logo
529 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
