Lost button on remote control(reset/lock button )
Need to find a new reomte for Electrolux/kelvinator Type R51K/BGE.can anybody tell me where I ban buy a new remote/
Thanks
H
  • 56 Answers
It is possible to google the manufacture and see if theyre tech support/contact us lines can locate one for you. Hope this helps.good luck
Posted on Feb 12, 2009
I have a kelvinator Electrolux split air con model r51k/bge it doesn't seem to keep coolits set on 17 and the control says cool the fan says high but no cold air comes out wat could be the pro
many reasons could be there, check that the outdoor fan working or not if yes my be the compressors is tripping, if no, check the volt for outdoor, check the gas and the leakage
Nov 21, 2014 | Electrolux Heating & Cooling
I just moved into a new home and the air cons are kelvinator r51k bgce and it won't turn on when i use the remote and the batteries are working?
pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
Mar 28, 2014 | Heating & Cooling
I have electrolux R51k ac its remote not fuctioning can give me soln..
sounds like the remote lost its language connection make sure they are talking first put in fresh batteries.clean remote
Sep 06, 2012 | Heating & Cooling
I have water dripping from the front of my airconditioner model R51K/BGE Electrolux Kelvinator
Check air filter, cooling coil and also drain pan for dust blocking. Clean it.
If
Dec 02, 2010 | Heating & Cooling
My dog chewed our Tv remote
Try website 1-800-remotes Factory original.Get the same or very close to the original.
Dec 15, 2009 | Philips Magnavox Learning Universal Remote
Lost original car alarm control... need to reset a new one...
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try.
Oct 29, 2009 | 2002 Volvo S40
Electrolux Kelvinator - Unit on defrost
When a heatpump goies into defrost, the unit is in a/c mode. and cool air is inside. You may have a bad reversing valve or bad defrost board.
Sep 25, 2009 | Electrolux E23CS75SS Air Conditioner
Hi, I have a KSR27g split system air conditioner. The unit turns on with the button on the front under the panel. The unit will not turn on with the remote (remote is brand new) have tried different...
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Jul 14, 2009 | Electrolux Heating & Cooling
Heating & Cooling Logo
448 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
