Question about HP Photosmart 2610 All-In-One InkJet Printer
Computer says printer is out of pape when paper tray is full
Dell 1720 and Dell XPS.
  • 23 Answers
Nothing to worry. There's no paper in the printer. Fill the papers up in the printer and start printing...
Posted on Feb 07, 2009
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
Cd jammed in a dell pp31l
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Jan 20, 2012 | SIB USB External CD-ROM Drive for Dell...
How to eject a cd in a dell XPS m1330 when the hardis has crashed and the disk inside isn't a operatindg system disc
Straighten a paper clip and insert it into a tiny hole below the CD drive tray. Push the paper clip gently into this hole and the CD tray will pop out slightly. Pull the tray out to the fully opened position so you can remove the disc.
Dec 28, 2011 | Dell Computers & Internet
When you try to print from a networked computer the display goes from saying ready to print to load Tray 1 A4. The tray is full of paper
When you loaded the paper in the tray, did you tell it that the paper was A4 - it may be that on the printer or in the queue definition on the computer that the paper size for that tray is set to something else (eg letter) and the print you are sending is A4 so it is looking for paper but only thinks it has other sizes available.
Nov 13, 2009 | Dell 5110cn Laser Printer
Dell 1720 printer prints crooked i.e. left margin is not parallel to edge of paper
most likely you have a bad pick-up roller. it is inside the printer directly above the paper tray. this is one reason the paper would pull in an angle.
Nov 12, 2009 | Dell 1720dn Laser Printer
Dell 1815 All in One Printer Says No Paper When Paper is Full
Most likely the printer is asking for paper in the Manual Printer Feeder (not the tray). Try put paper in the MPF.
CHeers
Sep 01, 2009 | Dell 1815dn All-In-One Laser Printer
Pages coming out crooked
Try to feed the paper on the tray properly..
May 18, 2009 | Dell Laser 1720 Printer
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
Toner leaking ink on one side of paper pretty bad
There could just be a lot of toner inside the printer, but it could also be the drum unit (which also collects the waste toner) is so full that it is leaking.
This typically happens when the 'replace drum' indication is reset without actually replacing the drum.
If you have reset this without replacing the drum, and the print count is in excess of 30,000, you probably just need to replace the drm unit.
Mar 05, 2009 | Dell Laser 1720 Printer
How can I un jam a paper jan in Dell 1720 laser printer?
Open the front cover and remove the toner cartridge to see if you can access the paper, if not open the top and inner cover to locate the paper and gently pull it out.
Jan 18, 2009 | Dell 1110 Laser Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
