The washer gets stuck in the agitate cycle.
The washer fills and starts wash, but gets stuck agitating between the 14 minute and 10 minute marks of the ''Ultra Clean'' cycle. The washer keeps agitating the clothes until the is turned slightly to the right, and then it finishes the cycle normally
  • sscottp May 04, 2009
    My washer fills with water and begins to agitate, but gets stuck there. I can push in the knob and move to the next cycle. It drains, then gets stuck in the spin cycle. I have to advance in manually again to rinse and final spin.
    Sergeant:
    Champion:
  • 373 Answers
Sound like a new switch
Posted on Feb 07, 2009
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Jun 15, 2017 | Kenmore Washing Machines
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
I turned the washer on. It started agitating
sounds mor like the pressure switch is stuck closed
Oct 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Nov 22, 2008 | Amana NAV2335A Top Load Washer
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
Washing Machines Logo
391 people viewed this question
Top Washing Machines Experts
