Question about Magic Chef CER3740 Electric Kitchen Range
My oven takes 45 minutes to get to 350 degrees
My Magic Chef oven will take a very long time to heat up to a low temp. When I make cookies, the oven will take at least 45 minutes to heat up to the required amount. Does anyone know why it takes so long or does anyone have the same problem?
  • zachnjeffsmo Feb 07, 2009
    It came with the house which is about 10 years old. I'm assuming it's the original stove but can't be sure. Will check with my neighbors.
  • jim beckwith May 11, 2010
    how alod is the stove
    Sergeant:
    Champion:
  • 373 Answers
I think it might be the heating elements
Posted on Feb 07, 2009
Magic chef smooth top electric free standing oven temperature
Most likely a bad temperature sensor if the bake element is coming on and not reaching temperature.
The temperature sensor is in the back wall of the oven up high on the right or left side depending upon your model number. It is about 3 inches long and about the size of a thin pencil. It removes from the inside of the oven.
Nov 19, 2009 | Kitchen Ranges
Oven is not reaching proper temperatures
You most likely have either a faulty thermistor or heating element that will need to be replaced.
Nov 10, 2009 | Magic Chef Kitchen Ranges
Oven goes on off on off on off and it does not get
This is a common symptom caused by a problem with the ERC (Electronic Range Control / Clock). If you can send us the ERC, we can rebuild it for you.
Bruce
www.fixyourboard.com
Aug 09, 2009 | Magic Chef Kitchen Ranges
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Wont Heat at all
sounds like you have a bad wire connection someplace in the oven.
Dec 10, 2008 | Magic Chef 9815 Electric Single Oven
Kenmore model 790 oven pre heats incorrectly off by 50 degrees
Temperatures vary for two main reasons, component tolerances and positioning of the sensor.
Feb 15, 2018 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven does not heat up
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
Sep 09, 2008 | Magic Chef CER3740 Electric Kitchen Range
Pilot light out/will not go above 350
Sounds like the thermostat controlling the gas valve in the oven is not working, I’m trying to find if the oven igniter is electric, but believe the igniter is electric. If it does light then not regulate the temp above 350 degrees, I am convinced the thermostat control is bad.
Oct 23, 2007 | Magic Chef CGR3725 Gas Kitchen Range
Magic Chef CER3740 Electric Kitchen Range Logo
781 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
