Question about Whirlpool ED2FHEXN Side by Side Refrigerator
HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
Whirlpool side by side refrigerator light will not work. the lights in the freezer side work. ensured new light bulb works, took out door switch and it seems good, have power to switch what is left?There is a irratic clicking sound coming from the lower right bottom of the fridge only when the fridge side is opened. The light does not come on and the LEDs on the controls do not light up either. The clicking goes away when the door switch is pressed. The freezer side light works fine. The fridge/freezer are cooling fine. Sounds like a bad relay???? Any help would be great!
Thanks!
  • Travis Reinert Feb 07, 2009
    The switch is working fine. There appears to be a relay or circuit down below that is making the noise and causing the problem.
    Top Expert:
  • Whirlpool Master
  • 64,034 Answers
Replace the switch, did you test the switch with an OHM meter?
Posted on Feb 07, 2009
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
My wife opened the refrig. door and saw a blue flash now all the lights in the refrig side are out and the temp gage indicator lights are out as well.
Blue flash sounds like an electrical short (spark) that blew a fuse or tripped a breaker.
Is the machine running? You need to unplug and check the switch that turns the light on and the lamp socket itself for frayed or broken wires befoe restting breaker or replacing fuse. Once your electrical problem is resolved you can reapply power
Jan 20, 2011 | Whirlpool GS6NBEXR Side by Side...
Refrigerator lights both not working. Freezer / Fridge LED Control numbers not lighting up. Still works fine. Freezer lights work fine. Whirlpool Gold Model GS5SHAXNL00.
Sorry to read about your problem, I hope this helps you out.
you lost a control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
Freezer not freezing on whirlpool side by side fridge. Its a 2001 model... ED0GTQXKQ00
Inside the fresh food compartment near lights is the defrost timer. Turn it clockwise slowly until you hear refrigerator compressor start. If this works, replace the defrost timer. Let me know, Thanks, Sea Breeze
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side refigerrator light stopped working even
1 does the light on the control come on when you open the door ?
2 does the freezer light work?
3 if yes to both then...the control board (light control) is faulty
Dec 16, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Gold side by side SR2659325
are you hearing a hum then loud click hold my rating till we are done
Mar 31, 2008 | Whirlpool ED2FHEXN Side by Side...
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
Jan 01, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
