Question about TruTech PVS31170S1W 17 in. LCD Television
I believe the backlight is out, can it be replaced? if so, cost?
Ive had this problem with dell monitors. i think this set has been knocked over a couple of times, but today there was a power surge/flicker.
  • tullurean Feb 07, 2009
    Thanks Stevo,
    it's my aunt's tele, so now i know. would you happen to have any idea about the cost of a replacement backlight?
    tullurean
    Right on,
    Thanks Again for the speedy reply, the tele is about 2 years old... so it looks like a lil bit green(back) for the light.
    the tullurean
    Problem Solver:
  • 6 Answers
Yes, just take your monitor to the repair shop & tell them what is the problem.
Posted on Feb 07, 2009
  • StevoT1 Feb 07, 2009
    If it's brand new & the Warrenty is still good it will cost you nothing
    but if not then your talking about $ 50.00 - $100
I think the backlight has failed. I replaced the
It will be the inverter module or the the back light that is the problem, but until you take it apart and examine the parts and do some testing that will be the key in finding the culprit.
Jan 17, 2011 | NEC AccuSync LCD92V (Black) 19 in. Flat...
My dell monitor have not backlight. what's problem and how i can repair it? Thanks.
Usually Dell monitors have a 3 year warranty, hence check with Dell. If your monitor is out of warranty this problem can be fixed by a tech who can open the monitor and replace teh backlight or the backlight circutis.
Dec 26, 2010 | Dell E153FP 15" LCD Monitor
It started flickering then went black. When powered off and then back on, it will work for a couple of seconds then go black.
Hi!
I think what your monitor is experiencing right now is because of the backlight inverter in your lcd monitor is about to give up...The backlight inverter is a cold cathode light thats responsible for the image in your screen.. if the lights located on the upper and lower edge of the monitor will be busted then what you will see is black screen.. You will need to replace that in your monitor.
However, without the proper skills to do that and proper tools to open the monitor.. it will be risky for the safety of your monitor..
I suggest that you bring your monitor to a credible technician to replace busted backlight or (burned high voltage ballast transformer - supplying current to backlight)
I hope this help..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I have dell 1907fpt, the lcd screen powers up for just 2 or 3 seconds.
The backlight might be bad. As far as I know, there isn't a way to replace that, so you'll have to get a new monitor.
Jul 17, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I have a dell latitude c400 my screen is dim. However I am able to use an external monitor.
If the screen is dim and and external monitor works, then the LCD backlight has failed. Replacement LCDs for that model are around $100 on Ebay and take 30 minutes to an hour to install depending on your skill level
Jun 06, 2009 | Dell Computers & Internet
Dell 24'' Ultrasharp went blank
I suspect the invertor supplying power to the Xenon backlight tubes has failed.
This can be reapired but may not be cost effective.
Ask for a quote from your local computer specialist but keep in mind the cost of a new monitor.
Mar 18, 2009 | Dell Computers & Internet
My Gateway laptop screen is dark and I believe I have to replace the bulb but how do I know which one to order? I have pulled apart the monitor but where to go from here? Thanks Dee
Just Search up the Make & Model Backlight Bulb of the LCD Screen. Example: (LiteOn LTR6543 Backlight Bulb). Don't forget about the Inverter, Most of the time it's Mounted below the LCD Display. That's what Powers the Backlight. Hope This Helps!...
Jan 31, 2009 | Dell Latitude D630 Notebook
My 3 year old Dell Inspiron 710m screen won't light up
to see if its your backlight, shine a torch onto the screen and if all is visible then, your backlight is out.
they are not expensive but getting someone to replace it may be.
Dec 20, 2008 | Dell Inspiron 710m Notebook
How can i open the case to see what the problem is
I think, it's bad backlight. you need to replace the backlight or the lcd.
Dec 23, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
TruTech PVS31170S1W 17 in. LCD Television Logo
61 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
