Mitsubishi 52825 lamp light wasblinking then tv went out put new lamp in and now nothing at all did I do ar not do something. what do i do is there a reset button or what please help
  • 19,396 Answers
Unplug power first.
Remove the lamp and reput it back in place, following thoroughly th instructions and ensuring that the door is well closed.
If you still get the erro , then that means that there is an additional problem, and you need to call a technician to test the internal parts.
Posted on Feb 07, 2009
    Genius:
  • 2,920 Answers
There is no reset button ..you ned to call a shop and have them come out and finish whatever repair you tried to do to get the tv to work again,thats my best suggestion
    President:
  • 1,990 Answers
Welcome to Fixya! It sounds like the Balast has Stopped Working for the Bulb. Or it could be a Bad Power Supply. I would recommend locating an Authorized Service Center for this Repair. Please Rate My Response! Thanks!
Green blinking light on Mitsubishi DLP 52825
Hello, unplug the tv and check the lamp to see if it is broken inside. here's a link on how to replace the lamp.....tks.... https://www.youtube.com/watch?v=3bQ0wut_pWg
Jan 26, 2015 | Mitsubishi Televison & Video
No picture
If you are not using the correct bulb, that is exactly your problem. Get the correct lamp.
Mar 15, 2013 | Mitsubishi 915p020010 Wd-62825g / We-52825...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
I need to see the lamp housing unit with connectors for the mitshubishi wd-52825. i replaced the lamp and have the same problem reported by most (no picture, then lamp light turns red). it appears as...
yes, if you look at the back of the lamp unit you will see a plug, if you pushed a little too hard when trying to plug it back in you may have pushed the corresponding plug out. Take the back off and look and find the case that the lamp sets in and see if the connector has been pushed out.
Sep 11, 2009 | Mitsubishi WD-52825 52" Rear Projection...
CAN SOMEONE PLEASE HELP ME
the 3300uf 16vdc caps are on the left side of the power supply board. the 1000uf caps were on the right side.
Dec 14, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi Mod. WD-52825 projection tv
9 times out of 10 it is not an easy fix. however ot is not an expensive fix either. checkout www.tv-techs.com
Oct 31, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Replaced lamp in WD-52825 but still no picture. Lamp indicator on.
the DM board has gone bad. it is not the 4 100uf caps on the board. it is surface mount parts. it this board has failed then the FMT board is not far behind. the chassis needs to be rebuilt. www.tv-techs.com
Aug 29, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
