Question about HP DeskJet 672c InkJet Printer
Print dark at top of each line of text, fades away at bottom
My system is XP and the printer is HP 672C which had been printing OK, then suddenly wasn't. I have re-installed the driver but that did not help, thinking that the files had been corrupted. Each line of text prints darker at the top but fades out at the bottom. The top portion that does print is 'grainy', ie, the individual printer dots are visible. What really has me confused is that the "Printer Test Page" prints just fine. I've tried printing from WordPad, Word files, and from website 'printer friendly' option, all with the same results.
Does anyone know where the problem is, and most importanly how to fix it?
Thanks, cslater.
  • 4 more comments
  • cslater Feb 19, 2009
    As I stated initially, the 'test page' prints just fine. If it were a problem with the printer, then wouldn't it also affect the 'test page' printing?
    Thanks.......
    Thanks.......
  • cslater Feb 23, 2009
    One of the first things that I tried was to install a fresh printer cartrige but the problem still exists. Also I have tried printing in the 'best' mode, and that also made no difference.
  • cslater Feb 25, 2009
    Thank you for the reply.
    My anti virus software (Avast!)automatically updates each time I go online, it runs continuously, and I have run a scan. Nothing was found.
  • cslater Feb 27, 2009
    Yes I have tried a different printer cartrige. The one that was in the printer when it began having problems still was about half full of ink. The new one that I installed was fresh out of the package. Before I installed the fresh one, I followed HP's instructions for cleaning so I'm pretty sure that's not the problem.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    The print spooler is not working. This is for XP, vista may be a little different but goes to the same place. Your printer is fine since it printed the test page. Follow this to reset the print spooler. Click on start>control panel>admin tools>computer management>on left side is Services and Applications. Click on "+" to open and click on Services. Scroll down until you see print spooler. Right click and restart or close/open depending on the options. Now go back and try to print again. It should work.
  • 63 Answers
Hi cslater! The problem might be due to Printers Settings. make sure the printer settings are the same as when you print the "Test Page" and when you print something else. If that doesn't work. Then there must be a hardware problem, as printers that print out the "Test Page" well but other pages not good. But do make sure the printer settings are the SAME!!
Posted on Feb 27, 2009
    Sniper:
  • 90 Answers
    Scholar:
  • 162 Answers
Hi cslater my name is scott. this is a common problem with inkjet printers and should be quite easy to fix, if you uninstall the printer completley then use add/remove programmes to uninstall any software which your pc is installed with from disc, then connect the printer again and search for the drivers instead of running the software on the disc. this should stop the conflict which you are having from another programme, possibly a drawing package or printing package.
Posted on Feb 25, 2009
    Scholar:
  • 165 Answers
Its not the printerdrivers problem or the problem of cartridges.its the clear problem of the golden dotted circuit of the printer to which the cartridge touches.that dotted circuit is connected to the main board through a thick cable.which actually moves with the cartridge holer carriage.its whitish brown in colout and four to five inch broard.that cable is got faulty.it gets short diue to many reasons.if its got cut in between this happens.if got short circuit due to moistute this happens.to replace that cable is not at all a simple job.the rate of new cable with its carriage is near to $ 15 plus the service change of the engineer who fits it.as the printer is very old.its very difficult to get this parttt and the company is now not making this cables with head assembly part.getting a new printer is much advisable.still you can try out near by local repair center for head cables reparing.
thanks.
Posted on Feb 23, 2009
  • 54 Answers
How old is your print cartridge? Did you refill it yourself? If so, there is your problem. Purchase an OEM replacement cartridge and it will work fine. My priter does the same thing after I refill the cartridge a second time seems the cheaper ink gums up the ink jets.
  • 1,800 Answers
U r under a virus effect update the latest database for ur visrus and run a scan .
Posted on Feb 19, 2009
    Sergeant:
  • 250 Answers
Its the cartridge problem because.while printing test page it printrs in best mode and while you print the documents its printing in normal or draft mode.due to this its getting faded.in best mode it consumes more ink so its printing the test page properly.either the cartridge is faulty or near to end so replasce it or refill it. thanks.
  • 544 Answers
the problem of your printer is not in software it is in the hardware..
so please go to the nearest shop and ask for the technician to open it for you because your printing set up is not working properly.
thanks,
Posted on Feb 18, 2009
  • 4,472 Answers
First try the printer on a different computer, but being that this is a very old printer, most likely it would require repair you can get a replacement printer for as little as 20$ brand new at walmart. Which is a much wiser choice. If you need further assistance let me know. Also please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Posted on Feb 07, 2009
  • Lee A.
    Lee A. Feb 07, 2009
    Also is the printer test page just color or black? its possible it has to do with the black cartridge.
    Thanks,
    Lee
    President:
  • 1,990 Answers
Welcome to Fixya! Have you tried Uninstalling and Reinstalling the Printer Software? You might also try Unplugging the Cables and Power to the Printer During this Process. Please Rate My Response! Thanks!
    Top Expert:
  • HP Master
  • 78,267 Answers
Have you installed a different printer ink cartridge? I have used this printer and other HP models, have seen this issue, and yes test page looked ok for me to, so install another cartridge and then try it.
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Looks like a braille text
Open the HP Printer Toolkit (this software was installed from the CD-ROM that came with the HP printer) and run a "cleaning cycle",
because some of the ink-jets are clogged, which results in the "all-white" horizontal lines, where some part of that line should be black.
Jan 05, 2010 | HP Photosmart 7450 InkJet Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
First print line print fades away across page,
The page size is off. Try readjusting it in your "printing preferences". Otherwise, if it is new, back to the store for a replacement. It really should not do that.
Sep 02, 2009 | Lexmark 2391 Plus Matrix Printer
Problem with printed documents
your printer needs calibration. Read in the manual how to calibrate ink cartridges and it should fix the problem up. Cheers
Aug 03, 2008 | Canon PIXMA iP1600 Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
Printing Problem With My HP cp1700D Color InkJet Printer
First clean the cartridge and then go to toolbox and give test print.
Feb 17, 2008 | HP cp1700 Color Inkjet Printer
HP DeskJet 672c InkJet Printer Logo
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
