Question about Toshiba Satellite L305D-S5895 Notebook
Laptop to tv
I am trying to connect my gateway laptop to my older sharp tv. I do not have an s video so i purchased an HDMI cable, that didnt do it so i purchased an hd dvd player? What all do i need and is it even possible? Thanks how do I find out if my graphics card is compatible with sending to tv?
    President:
  • 2,559 Answers
If your tv don't have s video input,you can get an Svideo to RCA cord.
If the tv does have s video input,just get an s video cable and plug it into the tv and computer s video ports and follow the steps below for setup.
Before you start, change the display settings to 800 x 600; you need to do this since most TVs will not support higher resolution settings - this is ok, however, since you do not need higher resolution to enjoy your DVDs or to view your monitor's display on your TV. Read below about TV/VGA resolution comparisons. Also, make sure all of the hardware is connected before turning on the computer; you may have trouble getting the video card to recognize the TV as the second monitor - the option on some Dells is to change to "Clone" in Nview. But "Clone" is grayed out unless you have the RCA connector on the far end of the "S to RCA" cable, terminated in a VCR or TV.
1. Connect the "S-Video to RCA" cable or the "Pro S-Video to 3 RCA" cable to the "S-video out" of the computer and to the "video in" (yellow RCA jack) on the TV. NOTE: This step must be performed before you start up the computer. Make sure that your TV is set to "recognize" the RCA/yellow video-in jack; you may have to play with the "aux 1", "aux 2", or "line-in" selections on the TV or the TV's remote control. The S-Video jack on your computer may be a 4-pin or 7-pin jack that is usually on the back of the computer.
Windows XP:
- Click on Start, Control Panel.
- Click on Display
- Click on Settings
- Slide the "Screen resolution" area slider bar toward Less until the setting reads 800 x 600. OK, you may not like how your screen looks at this setting after usig high-res settings, but you'll certainly enjoy your DVD on your TV!!! You can always change the res back when not playing DVDs.
- Click Apply
- Press the FN key and your computer's corresponding "F-number" key. For instance, on some Toshiba laptops you press the FN+F5 or FN+F7 simultaneously four times to get the TV-Out setting. The "FN" key is a short-cut key on most laptop keyboards. Note, the combination keys that you may have to press depend on your laptop.
- Start playing your movie or presentation.
- There may be additional adjustments that may be required. If the TV display is shifted to the right with a black vertical bar on the left side you will have to perform additional settings. "The computer runs Windows XP Pro and has a "Radeon IGP 345M", Under 'Display Properties', 'Settings', 'Advanced', 'Displays', click the "TV" button, then 'Adjustments' tab. There you will find options to change the vertical/horizontal size and position. Once you have switched over to use the tv you can simply adjust these settings while you watch the display on the television to get it looking the way you like."
Microsoft Windows 98, Microsoft Windows Me, or Microsoft Windows 2000:
NOTE: To use the TV as the primary display with the dual display function, you need to enable the TV setting every time you start your computer.
2. Click Start, point to Settings, select Control Panel, and choose Display.
2.1 Under the Display Properties window, ensure that the color depth is set to High Color (16bit)
2.2 Click Advanced Properties under the Settings tab; this brings up the ATI or SAVAGE video card features.
2.3 Click on the Display tab; this gives you the output options.
2.4. If you have an ATI video card the "Displays" tab gives you the output options. If the TV is detected, it shows the power button on. The button next to that gives you adjustments for the picture, kind of like those to center the view on your monitor. On the bottom are some blue buttons.
2.5 Make the TV the primary display and the monitor secondary. The default settings on the rest of the adjustments may not need to be changed.
To make the TV the primary display you have to select "monitor 2" (you do that by selecting monitor 2 with the mouse" and then "moving it" to the left of "monitor 1". By switching the position of the monitors in your display settings you effectively make the monitor on the left the primary monitor.
Videos and mpegs play on an "overlay" method and can only play on one monitor at the same time, thus, you have to decide which monitor you want the video overlay to play in...and since the idea is to watch the video on your TV, you thus have to make the TV the primary monitor.
2.6 If you have the SAVAGE graphics card you need to do the following on the display tab - go to the settings tab. There's a drop down menu with 2 monitors, select the first one. Click on the advanced button. There's a tab titled "s3 duo vue". Choose that tab, and click on the tv option. If you do not follow these steps you'll get a message from the savage image card control stating "You must activate the tv first." NOTE: To use the TV as the primary display with the dual display function, you need to enable the settings every time you start your computer.
3. Click OK to close window.
3.1 Click OK to apply the changes
NOTE: The S-Video to RCA Adapter must be attached to the unit or the TV option will be grayed out.
4. When the DVD player was showing the movie, the TV will display it, but the monitor window will be black unless you have dual display capability on your computer.
5. Your TV may just happen to be able to support the 1024 x 768 pixel resolution that the computer may be set to, however, if you lower the resolution to 800 x 600 the movie will probably play much smoother without any noticeable drop in picture quality.
6. Video Formats. You need to make sure that the video format selected on your computer is the same as the video format required for your television. There are some computers that are sold in the USA with PAL-B as the default video format; you need to change it to NTSC-M for TVs in North and South America. There are basically three television video formats, NTSC, PAL and SECAM. NTSC is used in Canada, Japan (NTSC-J), USA, Mexico, Central and South America. PAL is used in most European Countries, Australia and New Zealand. SECAM is primarily used in France and the old soviet republics.
Remember that your monitor's VGA resolution and TV resolution is measured differently since they are different standards and were meant to be seen at different distances. If "pixel resolution" was used to measure TV (NTSC) video then the approximate resolution of a regular TV would be 448x480. Your TV does not need to have higher resolution since it was not meant to be seen as close as your monitor. Regular TV was meant to be seen from a viewing ratio (viewing distance to picture height) of 4-to-1. An HDTV usually has a larger screen size and thus requires higher resolution, since the viewing ratio is about 3:1. You may have to re-arrange your TV viewing distance if you get an HDTV - since it's not going to look good if you just plop it in the same spot as your analog TV; you have to adjust the viewing distance.
Please Rate this a fixya
Posted on Feb 07, 2009
    Sniper:
  • 57 Answers
Hi there its not possible to conect a hdmi cable from your laptop to your tv its somthing iv never herd of but if your laptop has an s video out put theres a sure bet that you will be able to send this to the tv using the graphic softwear that cam with your laptop hope this helps a little thanks
2 Suggested Answers
cgpatel1948
  • 258 Answers
SOURCE: laptop to tv
Is your Graphic-card is compatible?
Posted on Jul 28, 2008
I want to connect my laptop to my sharp smart tv
hi look at your laptop for hdmi port if it has one connect hdmi lead if it hasn't connect vga cable from laptop to tv thanks
shaun
Mar 18, 2017 | Sharp Televison & Video
How to connect tv to laptop
you would need a HDMI cable I purchased a 25 foot cable at amazon.com for $20 they are about 85 at walmart for a 15 foot cable of course you nee a hdmi output on your laptop and a hdmi input on your tv they should have them if they are fairly new. hook up cable, select correct source on tv, mine is hdmi 4 .go to your laptop right click on background select properties from menuset up tv like it is a second monitor for your laptop. enjoy
Jan 12, 2012 | Sharp Computers & Internet
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
Hello
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
I have connected a Roku Digital Media Player to Sharp AQUOS TV, I am able to get the video but no audio from TV, Audio cable and all are setup properly. Can anyone suggest me? also i see the same problem...
Use the HDMI cable on the Roku. The reason you don't have audio from the laptop is because the HDMI out on the laptop has no audio on it. You need to use a 3.5 mm audio cable to connect the laptop audio to the TV.
May 26, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Gateway laptop to phillips tv
Hi, there, pleasy clarify the following:
What is your Gateway model? Is your TV an older tube type or a new HDTV? Does it have other input ports besides the standard cable input and the RCA you mentioned? You may be able to use S-Video if your laptop has the output port and so does your old TV. Or if you have a newer laptop that includes DVI and you have an HDTV, then you can use a DVI to HDMI cable which by the way will result in the best image quality.
Jun 24, 2009 | Televison & Video
What type of cable for laptop to Tv?
In order to hook a laptop or any computer to a tv you have to have the right video card with the correct video connections like hdmi or s-video. If you don't have those connections then you can't hook a laptop to a tv.
May 05, 2009 | Sharp 19 in. LCD HDTV
Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Sep 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Laptop to tv
Jul 27, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite L305D-S5895 Notebook Logo
1,016 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
