Question about Dell A940 All-In-One InkJet Printer
Printer stops printing after 8% , THEN FINISHES WITH BLANK PAGE
I have plugged and unplugged both 940 and computer,have checked new cartriges for alignment and still get same results
Try changing the print quality setting
Posted on Feb 07, 2009
Printing blank paper
At a guess you've bought a compatible generic cartrige. I had a similar problem different printer.
I had to by a genuine cartrige, worked fine. Contacted the generic cartrige provider, explained the problem. Returned cartriges and got refund no problem.
It looks like the generic cartrige makers are seeing some solutions to chipped cartridges but not all.
Mar 13, 2010 | Dell 922 All-In-One InkJet Printer
Colour Printing on a Samsung clp 500
Try unplugging printer from the power and connecting it back.
Try also extracting all toners and putting toners back.
Oct 30, 2008 | Samsung CLP-500 Laser Printer
Ink Levelos are blank after replacing black cartrige and still will not print
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Jul 01, 2009 | HP DeskJet 5150 InkJet Printer
Low toner advise keeps on after changing toner and/or printing
Have you tried to unplug your printer and plug it back in, that will force the printer to re-check all its settings and it should notice that the toner is now full.
May 27, 2009 | Dell 1110 Laser Printer
LEXMARK 125 PRINTS BLANK PAGES
have you when into printer properties and done maintence such as "clean cartriges".  If so, it may be possible the ink cartidges are bad.
Mar 01, 2009 | Lexmark X125 All-In-One InkJet Printer
Samsung printer ML-1450. When the first page is being printed, paper stop at half-way. Open the lid and close it again, it finishes printing the first page and spills out a blank page as well. This problem...
my printer not work in win xp and also in dos i send data to printer but first line of first page come true after that print another text that havent any meaning what can i do?
Oct 14, 2008 | Office Equipment & Supplies
After changing the blank ink cartridge a test print was done. Now every time I switch the printer on to print a page I get another test print page before i can print what I need to print. This is stressful...
hi my name is pete and hope you are not stressing out to much here how you fix your printer when you change a blank ink carriage and stop printing off test prints you will notice on the back of the inks theres a chip something like what you would find on a visa card now the printer uses these chips to reconise the carriages are there so the ink will work now unplug the printer from the computer and switch off the printer from the mains leave for 10 minutes so it can reset the inks for you after doing so plug the printer back in but dont plug into computer yet let the printer set it self up when ready plug back in to computer open programme you use and find out if the test page is on or got a tick on it if so click it off and then try to print anymore problems let me know
Oct 06, 2008 | HP Office Equipment & Supplies
DELLA 940 DOES NOT PRINT
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jul 20, 2008 | Dell A940 All-In-One InkJet Printer
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
Reformatted computer worked while now recives faxes wont print
Uninstall all of the software and go to this link http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:439:0:0 install the updated version of your printers software and let me know what happens.
Jul 19, 2007 | Lexmark X4270 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
