Question about Acer Aspire L100 PC Desktop
Acer laptop shut of during power outage .
When you push the lever to turn it on, nothing happens, i had this happen to 2 other acers, i unpluged them and they came back on. help me. Grandfather
  • 565 Answers
From the Acer website:
Product
Notebook
Issue
Power Issues or Will not Boot
Solution
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Posted on Feb 07, 2009
My acer Travelmate 242lc will not power on
First think , has it been dropped, jarred, banged, .....you get the idea? Does it continue to blink, the HDD? Do you see a "ghost image" in the monitor in a bright light? Do you here sounds? You say "nothing else happens", meaning the light stops blinking? Shut down, unplug, remove battery, plug in, try to boot noemally.
Nov 16, 2012 | Acer TravelMate 242LC Notebook
Acer 5733 will not turn on
No solution, mine does the same exact thing but blinks orange five times. I got an error message that said click to fix it. I did it and the computer tried to reset itself but simply died. With brick cord out...nothing happens. Same with battery same with power cord in. The battery was fine. It may have died during a forced windows update. I hope someone comes along otherwise it's "buy a mobo" and buy a battery and so on....
Sep 06, 2012 | Acer Aspire 5733Z-4633
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Battery was running out on my Acer mini book, hibernated and turned of, tried to turn it on nothing happened., used ac adaptor....still nothing
take battery out, unplug ac adapter. Wait one minute. leave battery out. Plug in ac adapter and turn on laptop. Once it turns back on. Shut down laptop and put battery back in. Now you should be able to turn laptop on with or without battery.
Nov 08, 2009 | Acer Aspire One AOA150-1635 Notebook
Acer Aspire 5610 power up problem
Push and hold down power button until it awakens. :)
Jul 12, 2009 | Acer Aspire 5610 Notebook
Shut off and won't come back. It's like it is dead.
you have a problem with the ram or the processor
May 30, 2009 | Acer Extensa 5420-5687 Notebook
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
I have a brand new acer aspire one. A moment ago, when I wanted to open it, I saw that the green light on its top right, that is, at its "start" button was on, and the battery was a bit displaced at one...
Most likely your laptop is going into sleep mode. Lots of them do not like sleep mode if nothing happens when you push the power button try to hold it down for about 5 sec. your computer should power off and then you can start as normal. If this problem persists change the options in your control panel to turn sleep mode off. That should solve it.
Dec 18, 2008 | Computers & Internet
Acer Aspire 5100
This is a duplicate posting, the main discussion can be found here: http://www.fixya.com/support/t133152-acer_aspire_5100
Feb 06, 2007 | Acer Aspire 3000 Notebook
Acer Aspire L100 PC Desktop Logo
262 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
