Question about Dell Office Equipment & Supplies
Unable to print from the internet using dell printer 948
I am able to print from my document files but not from the internet. The computer and printer is only 1 month old. Dell stated it was a software problem and could resolve for $69.00. Today is the first time I have attempted to print from the internet. Please advise. Thank you.
  • ntlives May 11, 2010
    Try looking at the printer properties (Start-Printers and Faxes). Which icon has the black and white check mark? That is the default printer. It should not be the Adobe, Microsoft Office Document Image Writer, Intuit Internal Printer, etc. An example would be "Dell Photo AIO Printer 964" or similar. If it doesn't have the check mark, right click on it and choose "Set as Default Printer". You can also test this by opening any web page, click on "File" in the far upper left corner, choose "Print...Ctrl + P" and see what printer is listed at the top of the dialog box. You can use the drop down list to choose the right printer if the wrong one is listed as default.
    President:
  • 623 Answers
We had a similar problem that the printer could not print online content (see here).
Turned out to be a Windows firewall problem and reinstalling the software solved the problem.
Just to make sure: open your firewall settings (Start->Control Panel->Windows Firewall) and disable it.
If you can print now form the internet, you found the culprit.
The easiest way to solve this problem is to either re-install the printer software and open the ports or look into your printer manual and find the information about necessary ports that have to be opened.
If you need more help with that come back here and leave more details (esp. which printer you are using) and I'm happy to help.
Posted on Feb 07, 2009
Dell 948 Printer Problem
Try uninstalling the printer software from the computer then reinstall.
Dec 10, 2013 | Dell 948 All-In-One InkJet Printer
Ihave a dellp513w and some how i put the disc in that came with it trying to get it connected to the computer so i'am able to print from the computetr and it want work. The disc want connect to the...
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Uninstall the printer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
With your computer online, Insert the printer disk or try using the drivers located at...
Dell P513w Wireless All-In-One Printer owners thread
You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block printer communications.
Rick
Apr 19, 2011 | Dell 948 All-In-One InkJet Printer
While attempting print a document, Dell All-In-One 948 InkJet Printer printed a document that was not opened. How can that happen? I haven't tried anything to fix it because I don't know where to...
Most likely, this document was already in the print queue and never got printed. If that's the case, open notepad, enter the following commands : net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Save this to your desktop as DeletePrintJob.cmd, run as administrator (right click on it, select run as administrator), then reboot your pc/powercycle the printer. This should resolve your issue. If not, please let me know.
Mar 05, 2011 | Dell 948 All-In-One InkJet Printer
I replaced a Dell 948 printer that was freezing up when printing. Now when I try to uninstall the software/driver for this printer, I get a message "wait for printer to finish printing, then uninstall". It...
Don't worry... you just have to delete the previous print job.
Go to start menu...
Control Panel...
Printers and Faxes...
Find your printer and double click...
This should show you the pending document to print...
Right click and delete that job and any other pending jobs...
If it is not deleting... try using the "Use printer offline" mode in the menu.
Again delete. This time it should work.
Jul 18, 2010 | Dell Office Equipment & Supplies
I lost my cd for my dell 948 all in one printer.my computer can't find the software.how can i download it?
Which OS did u used?
For Windows XP OS :
Click Here
For VISTA / Windows7 OS :
Click Here
if u wanna chose the other file (such the firmware or others) u can see it at http://www.dell.com/
Dec 16, 2009 | Dell 948 All-In-One InkJet Printer
Dell 948 printer will not delete a document
try putting a sheet of paper on the printer and hit the print button..
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
Dell 948 printer- won't print in black and white
I had this problem. It's actually very easy to fix:
- Click Print -> Properties
- Go to "Advanced" tab
- "More options"
- Deselect "Use color cartridge for all black printing"
- Select "Use black cartridge to print black and white"
- Click "Ok"
You should be able to select the "Print in black and white" option now and stop all the frustration!
Anthony
Feb 05, 2009 | Dell 948 All-In-One InkJet Printer
My printer/scanner/fax machine needs to be reinstalled
i have an hp not a dell but my printer does kinda the same thing
i tried re installing the the driver software and it worked ok
Jan 06, 2009 | Dell 948 All-In-One InkJet Printer
Dell 948 printer printing not finishing print jobs
Your printer loose documents:try to reset it ,unplug for an hour.
Or you might have interferences on your wireless :DECT phone, cell phone, or even an electric device who doesn't work propely, like tv, stove, speakers many things can parasites your connection...
If nothing does your printer as issues, think replacement...
cheers
Dec 19, 2008 | Dell 948 All-In-One InkJet Printer
Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Nov 03, 2008 | Dell 948 All-In-One InkJet Printer
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
