Question about Sony STR-DE197 Receiver
Still cant get my adc equalizer to work with my receiver
Yes i am still trying to get my adc soundshaper two mark 3 equalizer to work with my newer sony str-de 197 receiver but no go.I had it working on an older 70s sanyo receiver and it worked good. But the old receiver quit working.The only thing different was the older sanyo had a tape monitor button on it.Where the new sony receiver doesnt.Then again you would think that it would still work as the equalizer has 2 tape monitor switches and has all kinds of jacks on the back side of it. Any suggestions?
2 Suggested Answers
  • 7 Answers
SOURCE: cant get equalizer to work with my receiver
This might work fish76, The EQ needs a in & out source to operate correctly? If you have audio device connected to an aux input disconnect that & connect the EQ to that audio device & then plug the EQ to the Sony receiver AUX input. The tape monitor is the most important source for hooking up an EQ device, so you are very limited on a total receiver or amp tonal connection source. The bottom line is you can only use the EQ if another audio source to plug into it & the EQ plugs to your pre-amp input on the back of your rec or amp
Posted on Feb 04, 2009
Manual download for adc ss-110 equalizer
Hello
Try these links
audio.manualsonline.com/manuals/mfg/adc/ss110.htmlCached
www.manualsonline.com/support/adc
http://www.dataentryjobs.us/67948.html
Feb 05, 2012 | Audio Players & Recorders
How do i put this model into defrost? mzd2766gew
The older Adaptive Defrost Control (ADC) boards - short L1 and TEST pins together (you can use the tip of an insulated screwdriver or short length of wire - stripped only at the ends). Newer ADC boards don't have a TEST pin. You can also force defrost by cycling the Cold Control 3 times within 6 seconds and leave it on COLD (this may work only for the newer ADC without the TEST pins).
Mar 09, 2011 | Maytag MZD2766GES Side by Side...
How do I hook up my older model Onkyo AMP (model# TX-20) to my ADC equalizer
use tape out from the amp to line in on the eq (observe left and right)than line out on the eq to tape in on the amp----whenever you select tape monitor and the eq is on your sound is equalized --enjoy
Sep 08, 2010 | Audio Players & Recorders
Code for a Gateway ADC-320 needed
Hi chris_vau888
You could try these codes :- 1100, 1104, 1185, 1221. If none of those work you could try the philips code lookup finder at :- http://www.urc.philips.com/ You will need the remote model number, either from the front of the remote or in the battery compartment.
Hope this helps,
Mark.
Mar 29, 2009 | Gateway ADC-320 DVD Player
I have an ADC equalizer model # SS-100SL i'm
record out-------equalizer in-------equalizer out------tape in
Mar 01, 2009 | Audio Players & Recorders
Cant get equalizer to work with my receiver
Feb 03, 2009 | Sony Audio Players & Recorders
Can I still used this equipment
Hi Jerome
You will need either a pre-in pre-out connection on the amp to use, A vcr in/out loop can be used in lieu of a "tape" loop. Or alternatively you can put the EQ in line with the bit of gear you want to EQ. In this day and age, of "many more than stereo" systems, a 2 channel EQ has much less application. Although this seems to "outdate" a piece of gear, most stuff from yesteryear still sounds great, so why stop using it. Good Luck and happy listening. A "FixYa" rating from you would help my profile. I am happy to answer any questions you may still have, put them in here and I shall get back to you.
regards
GRaeme
Jan 21, 2008 | ADC Kentrox SS-315 Home Equalizer
Graphic equalizer
In general all equalizers, being designed to be in a Tape Monitor loop, have the option to Equalize either the Source or the Tape or nothing. Check for that control and toggle it. My old ADC SS-525X has pushbuttons whose settings (Tape/Source) are not easily determined. I always have to play around with it to know which is selected.
I'm betting your EQ is processing the program that would head out to an attached tape deck.
Nov 14, 2007 | Onkyo TX-8222 Receiver
Sony STR-DE197 Receiver Logo
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
