Question about Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater
How to adjust bthe pilot light
Pilot light burns to high are they a way to adjust it
  • Dyna-Glo Master
  • 2,602 Answers
Try cleaning it out first could be blocked injector ,
Posted on Feb 07, 2009
Pilot light is to high and all burner are red but the center and it burnes blue on a list world knw321 what could be problem and how do I adjust the pilot light it is to high
You've got a red flame then you need to shut down the unit IMMEDIATELY!!!!! This due to incomplete combustion and could be due to a lack of fresh oxygen entering into the unit, or the units exhaust is block somewhere in the line. Shut it down now and call an expert!!!!! Gas Flames Yellow vs Blue Gas Flame Colour Temperature
Jan 22, 2017 | World Heating & Cooling
I have a kozy world knw321 and pilot light is to high can this be adjusted i have tried blowing it out other heaters are burning fine but this one is burning to high don't know how to adjust it
Yes,pilot should be adjustable, but problem may be dirty accumulation on pilot fixture. With gas SUPPLY off, remove the grill and clean the pilot orifice and anything that might block air getting to the flame.
Check the hole where gas comes out of the pilot for accumulation of deposits. DON'T enlarge this hole beyond its original size.
On adjusting, you look at the gas valve and find a cap or screw that is identified PILOT adj.The actual adjustment screw is sometimes under the top cap or screw. If you're not sure, call someone who is knowledgeable.
Turning this slightly will adjust flame. don-ohio
Pilot light wont stay lit, even when on high
Pilot lights are supposed to stay on when the flames are burning. If they didn't the flames would go out, because the pilot flame against the Thermocouple keeps the pilot burning. It's a safety feature.
Mar 08, 2011 | Heating & Cooling
Pilot flame burns above pilot tube in propane heater. the sensor does not register. the pilot top of the tube shoul glow red. I have cleaned the tube, in few occasions it has lit and worked for above 10 to...
Hi it there a leak on the pilot causing it to burn that high can you adjust the pilot gas going in to the pilot ?
have you cleaned the pilot injector out or is the hole in the injector too big
Jan 25, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Delayed ignition of a Ruud high efficiency upflow 90 plus propane
It sounds like the first thing to do is have burners and pilot cleaned and adjusted so ignitor and pilot flame is close to main burner ignition rail.
The "whoosh" is due to delayed ignition because the pilot flame does not come in contact with main gas.
One more thing that should be tested is the gas pressure and combustable air mixture to be sure it is correct.
It is always best to have a qualified technician do this for you, In many areas the gas supplier with check and safety test this for you.
Nov 24, 2009 | Ruud UBHC Air Conditioner
Pilot burns very high. Can it be adjusted?
Pilots cannot be adjusted on vent free heaters.Pilot should be replaced
Nov 05, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
Pilot adjustment on Williams wall heater
The insert sounds like the cap covering the adjustment screw. Pin hole is for cap removal. Wondering why flame is so high?! Shouldn't have orange flame. If heater doesn't light with lower flame... thermocouple (thing that the flame heats up) may be bad.
Dec 02, 2008 | Williams 2509612 Ceramic Mid-Size Heater
The pilot light won't stay lite
Flame is way too high on pilot . blocked injector or hole on injector is too big . Being sucked off by main burner .
Jul 04, 2017 | Dyna-Glo (PPH16-LP) Utility Heater
Pilot light seems to high
there may be an adjustment screw for pilot height. you'll have to look at the valve. a pilot should have an inner cone of greenish blue color and the surrounding flame should be a deep blue no yellow or orange tips. the pilot burns pure fuel no air. the main valve does mix air with the gas in order to burn.
Oct 24, 2007 | Procom ML300EBC Heater
Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater Logo
288 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
