Question about Philips AZ2785 Cassette/CD Boombox
Tape decks quit working (turning)
Philips AZ2785 Cassette/CD shelf unit/boom box. The tape decks quit working. Was using it, stopped the deck to talk on phone, pressed PLAY and would not turn anymore. Neither side will turn. I do hear a noise, like a motor sound, or a hum, but the spindles (?) do not turn - with or without a tape in. I am a 62 year young lady who truly loves this machine and hates to be without it. Can't find "goodies" like this much anymore. This one was manufactured in August 2001. My common sense guess would be a belt? Is this something a mechanically minded gal could tackle? If so, where to get parts? THanks SOOOO much for any advice!
  • 4,234 Answers
There are a couple of belts inside this unit that most likely need to be replaced. Unfortunately this is not the easiest unit in terms of access. I would not suggest an attempt to replace the belts yourself if you have no experience with that sort of thing. The belts should not cost more than $10 total. Check in your area for a service shop that handles audio gear. The total repair cost for this should not exceed $75.
Dan
Posted on Feb 17, 2009
How to record a cassette tape to a cd
Your question is posted under a "CD Shelf System" heading. If you really have one of these, the answer is "you can't". The CD player is a player only, not a recorder.
On the other hand, if what you're asking is how to transfer cassette tapes to CD using a computer, there are a couple of ways. One is to connect a cassette player (boom box, component system cassette deck, etc.) to the line-in jack of your computer's sound card. Download and install Audacity, which is free software for recording and editing sound. Then you can record the sound from your cassettes as you play them into the computer.
Another option, If you want to be fancy and spend a little money, is to buy a USB cassette deck. It automatically converts the cassette audio to digital and sends it to your computer over a USB cable. Recording software is supplied (sometimes the Audacity program mentioned before). Several companies make them. Here's one from a company called ION that some friends of mine have, and it seems to work well for them. They've been converting a lot of tapes of family members, and Audacity has been good for cleaning up tape hiss and enhancing the sound.
Either way, once you have the sound in your computer and processed to your liking, you just need to burn it to a CD using whatever burning software you have. (I use CDBurnerXP. It's free, easy to use, and does everything needed for normal CD and DVD burning.)
Aug 10, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Feb 23, 2010 | Aiwa Audio Players & Recorders
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
Clicking
open the cassette holder and use a pen to push down on the carrier. So long as you don't try to use it again it should stop
Jul 09, 2008 | Sony MHC-RXD3 CD Shelf System
Loud clicking
Open the cassette deck and use a pen to push down the heads. After this it probably works better to avoid using cassettes in this machine.
Feb 16, 2008 | Sony MHC-RXD3 CD Shelf System
Denon d-c30 cassette problems
That guy (Dries Hyman) has no idea what is he talking about. I have the same problem with my D-C30, and solution is simple, all you need its change the tape deck belt. (but, its very hard to access it if you going to do it by your self)
Dec 29, 2007 | Denon D-C30 Shelf System
Cassette player will not work
common fault on the JVC tape decks is the belt stretch and then it does a clicking sound its trying to pick up the audio heads. changing the belt is quite hard if you have`nt done it before.
craig:)
Sep 09, 2007 | JVC MX-J900 CD Shelf System
Philips AZ2785 Cassette/CD Boombox Logo
190 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
