Question about Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560
Intermittent problem with isolated pages with blurred print -
can be first page of multi-page document or 15th page -
have done maintenance kit -
Help!
  • 1 more comment
  • ks319 Feb 11, 2009
    Where is the "encoder"?
  • carol837 Feb 13, 2009
    Ok - I' m not finding the encoder - what does it look like..exactly
    Thanks
  • shawntdg Mar 04, 2009
    We have the same problem with our Xerox Phaser 8560 MFP.  Xerox said to change the maintenance get, which we did, and still same problem.  It's not every page.  It may go a whole day and not print a blurry page, then when you're printing a document, one of the pages will be blurry.  It's intermittent.  We cannot find a reason for it to happen. It's not a pattern problem.
    Would love to know the fix on it.
    President:
  • 2,072 Answers
On the right side of the machine. There is an encoder mounted to the end of the drum shaft. They are known to become contaminated with the silicon lubricant from the maintenance kit. That causes the drum to spin off speed somewhat randomly. You can take it off the shaft and clean it well with alcohol. Sometimes they need replaced, but if it is as intermittent as you are suggesting cleaning it should take care of your problem. Not all that uncommon.
Posted on Feb 07, 2009
Shadow Printing on a xerox Phaser 8560. Have changed the Maint Roller and done the various cleaning cycles
The printer requires a maintenance kit. (95% chance anyways)
I would suggenst the extended life maintenance kit (10,000 page lifespan) part number 108R00676 to correct this issue.
You can usually get these where you get your solid ink cartridges.
Feb 25, 2011 | Xerox Phaser 8560DN Laser Printer
Xerox phaser 8560 1st page is blurry. The 2nd page is OK.
The good news is that you don't need any parts.
The oil from the drum is drooling to the right side to the Drum Position Sensor is located.
Remove the right cover. Remove the fan. Loosen the clear plastic cover under that. Clean the sensor and all the wires with very pure Isopropyl or denatured alcohol.
The situation may reoccur every year or so.
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560N Laser Printer
My xerox phaser 8560 is printing muted color
First off on your screen access troubleshooting, and perform the remove light strips and also remove smears and skips.
Next go to Xerox.com, under support and drivers enter 8560 in the search box. then go to the support page.
You want to look up the procedures for TEC color correction. And follow those steps.
If you are using a generic ink then, all bets are off in getting true color reproduction.
Feb 10, 2010 | Xerox Phaser 8560DN Printer
My print jobs keep coming out with smears in certain spots and now the entire print job is blurred. I've cleaned it several times. How do I correct that myself?
If the entire page is blurred, it is probably a dying wave amp board. Time to start shopping because the repair bill is more than a new 8560.
Jul 08, 2009 | Xerox Phaser 8400 Laser Printer
I HAVE A XEROX 8560 THAT I AM GETTING BLURRED PRINT WITH, I DID THE CLEANING CYCLE AND THAT WORKED FOR A DAY AND A HALF. NOW THE FIRST TWO PAGES LOOK GOOD AND ALL THE REST ARE BLURRED?
Oil from the drum has ran off over the drum encoder position sensor.
Take the right cover off and find the fan. Remove it and loosen the clear plastic sensor cover underneatch. Clean the sensor and generally with Isopropyl and Q-tip.
Clean the nearby wires and anything that might be transporting more oil back to your sensor
Apr 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Unreadable characters
check if the file is not currupted.
and the printer is set for RAW printing, probably dont have enough memory, to print the document
try printing like only 10 pages at a time to see if the last 10 print
if it does might want to invest some money in some printer memory
Jul 15, 2008 | Xerox Phaser 8500/DN Printer
Phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Jul 11, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
1,424 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
