Question about Masterbuilt Master Barbecue 7 in 1 Smoker - M7P
Not enough screws to put smoker together
We won a Masterbuilt outdoor LP Gas smoker - grill- cooker as a door prize a while back, but didn't have a chance to put it together until now. The only screws in the box only covered putting the legs on, all other screws for the rest of the grill were missing. Can we get the rest of the screws so that we can get this good lookin grill all together.
Thanks, Ronald Comesana
Model SMM7P, Serial # 06015AHOL
Don't know if you've already solved this problem, but when we put ours together, we thought we had the same problem, that there were missing screws. After reading the directions more thoroughly, we learned that most of the screw-holes were "self-threaded", eliminating the need for the washers and nuts.
Posted on Jul 19, 2009
  • 360 Answers
From Master Built;
If you have any questions about your unit ( or a part is missing )
give us a call FIRST before returning it to the retailer.
Ask For The Customer Service Department:
(800) - 489 - 1581 Fax (706) - 327 - 5632
Your owners manual is available for download
-->click here<--
Thanks for using Fix Ya, please take the time to rate this a Fix Ya solution.
clarkco
Posted on Feb 07, 2009
Does anyone know how I can obtain a manual for a Masterbuilt Turkey Fryer & Seafood Kettle combo cooker?
Here's a manual for one of the older models. They are all fairly similar. Note the cleverly hidden reset button in the handle, most Masterbuilt fryers have one and frequently it is the only thing wrong!
https://www.appliancefactoryparts.com/content/pdfs/137637-1.pdf
Nov 27, 2015 | Masterbuilt Grilling
I have an LP version of Ultra Chef Elegance 315 grill and need to convert it to natural gas. Napoleon does not sell the kit any more.
Jim, the reason Napoleon no longer sell a gas conversion kit is a matter of safety. None of their grills are approved to be converted from one gas type to another. Which is also the case with 95% of all the grill brands on the market today. Grills are tested and approved for the gas type they represent. Changing the gas type, then puts the burden of liability on you, if something should go wrong.
Most people want to convert them, as a matter of convenience. Not having to deal with refilling the LP gas tank. But, are disappointed with the operation of the the grill, once it's converted to Natural Gas. As, it takes longer to preheat the grill and the flame height of the burners is lower than with LP Gas.
The reason for this is that LP Gas burns cleaner & hotter in an outdoor environment than Natural Gas.
There are no complete conversion kits available. If, in the end, you decide to make the conversion, you will need to piece and part a kit together. And that's not including running a hard line to the grill's location., along with an inline gas shutoff valve and a quick disconnect gas hose to the grill.
I hope this helped you to make the right decision and err on the side of caution and safety.
Thanks for choosing FixYa and Happy grilling!!
Sep 06, 2011 | Grilling
Bought a brand weber sprit grill from home depot. Used 4 times. Won't go above 350
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ';';
Aug 11, 2011 | Weber Genesis Silver B Grill
I purchased a used Masterbuilt veranda gas grill. The gas regulator fits a small propane tank. Is it possible to replace the regulator so it will fit a large sized propane tank?
Yes, it can be converted to accept a 20 Lb LP grill tan. Contact Masterbuilt Customer Service
1.800.489.1581 to obtain the new hose/regulator assembly.
Hope this helped you and Happy Grilling!
Jul 22, 2011 | Masterbuilt SBMPG3 Veranda Steel Grill
My weber grill won't heat up beyond 200 degrees - why>
heatman101 ,,./,./
May 28, 2011 | Weber Genesis Silver B Grill
Recently purchased a Masterbuilt Vertical Gas Smokehouse LP Smoker #15888 from a Sears going out of business, they did not provide instructions on how to use
Are you certain of the Model Number you furnished? As it does not match any of the Masterbuilt Smokers (Electric, Charcoal or Gas) in my current, up to date, data base.
Please advise. Thanks.
May 05, 2011 | Grilling
We have a Big Easy oil-less turkey frier & it won't stay lit. It's 37 degrees out. Would that be an issue? When valves are open, can't hear gas coming through. We've only used the propane tank one...
Yes, the outdoor temperature and any wind could play a role in it. Check to be sure that there's enough gas in the tank, to sustain the burner flames. These cookers use a lot of gas. Also, check the air intake shutter valve (where the tank hose connects to the burner). It may need adjusting to get the proper mixture of gas to air ratio. Consult your Owners Manual for the proper setting.
Hope that helps. Please let me know.
Rich
Feb 06, 2011 | Char-Broil The Big Easy 4638235S (LP)...
Masterbuilt Master Barbecue 7 in 1 Smoker - M7P Logo
160 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
