Question about LG CHOCOLATE VX8500 Cellular Phone
The battery meture will go from 4 to 1 in one min! HELP!
OK well I'll charge my chocolate for oh maybe 12 hours and then 5 seconds later the battery meeter will go from 4 to 1 and then turn off! What do i do? Is it the battery? The charger? WHAT DO I DO!!!??????!!!!!!!!!!!!!!!1
  • 101bgsneezy Feb 07, 2009
    thx mastersaintz that helps, but the problem is that it's only like mounths old and do you have any idea how much a battery for it will cost? (i only need an about)
  • 101bgsneezy Feb 08, 2009
    K thanks so much and my sister jsut told me today that she has another battery ugh she always tells me so late! and really that helps a lot thanks again!!!!
  • 928 Answers
Normally this means that its time to replace the battery as it cannot hold a charge any longer.
Posted on Feb 07, 2009
  • Thomas Lim
    Thomas Lim Feb 07, 2009
    The battery is abotu $5 to $15 depending on where you buy. If its only months old it should still be under warranty where you bought it.
Will not transmit out going calls -
Maybe the kit has a warranty then you can claim it.
but if none, then you have to self tech the unit by disassembling it cause some part in it got busted or grounded. avoiding risk then maybe bring it to the repairman near you location.
melnavz
Jul 25, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Tring to add a handset to a att 5840 base!
The process is called "Registering."
From another fixya post:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Mar 21, 2011 | AT&T 5840 Cordless Phone
My phone wont turn on or charge even tho i charged it all night
It sounds like you need to replace your battery. But first, if you're using a home charger, try charging the phone with a car charger (or vice versa). If the problem is not with your charger, then replace your battery.
When you get your new battery:
1) Make sure you are using the proper charger for your phone (not one of the cheep $5 kind), and
2) charge your battery for at least 12 hours before you use it for the first time.
Click here to see a battery for your phone on eBay: http://cgi.ebay.com/NEW-OEM-LG-VERIZON-VX8560-CHOCOLATE-3-LGIP-330H-BATTERY-/250764708864?pt=PDA_Accessories&hash=item3a62bdcc00
Jan 28, 2011 | LG Chocolate 3 Cell Phone
My kin-1200 ap doesn't charge the battery properly.
The reason for this is that the UPS, is unable to efficiently charge those BIG batteries, you see they generally only charge at a low rate, anyway, of say 10% - 15% capacity, of the-battery-usually-charged. Now with these BIG 40 Amperes by 2, well, there simply isn't enough "Juice" to charge them up... (Oh it might do in a month or so)... from that UPS's Charging Circuit. You will most likely have to rig up some other higher rate charger for those BIG batteries. OR modify the charging circuit IN the UPS. They need to be charged at about 1 Amp or maybe more. See it is simply Charge over Time... 40 amps at 1 Amp will take 40 hours.. 40A at 2A = 20H & so on. If only 1/2 flat 2A over 10hours.
Feb 07, 2010 | Powercom King Pro UPS System
Oh where Can I find a VGN-SZ330 batterr replacement?
Maybe you can take a look at VGP-BPS8. it has 6cell 9cell and 12 cell VGP-BPS8 battery. You can buy the 12cell it can last 5 hours.
Dec 16, 2009 | Sony VAIO VGN-SZ330P/B Notebook
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
Oct 31, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Razor v3 wont charge is there anyway to fix the problem
Hi
It seems like you need a new battery, you can get a replacement one for cheap on Ebay.
David
CellUnlock.net
Feb 26, 2009 | Motorola Mobility RAZR V3
LG CHOCOLATE VX8500 Cellular Phone Logo
53 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
