Question about Lexmark Z645 InkJet Photo Printer
My printer will not print
I click on print in my documents and the printer does not respond.it is installed correctly and it was printing before
  • 23 Answers
1)Check whether the printer is connected properly or not, by going through CONTROL PANEL --> PRINTERS.
Here you can see which printer has been connected to your PC, if you've more than one printer.
2) Before giving print to your document, press CTRL+P. A dialog box will appear, which has all the print options. There you can find to which printer, it has been connected.
Make sure, the printer's name in 1) and 2) is same.
Else, if you are using only one printer and it has been connected properly and installed, Make sure the ink catridge is not dry. Your catridge may be new one, but if you let it ideally, without using for some day, it'll become dry.
Posted on Feb 07, 2009
  • 18 Answers
SOURCE: my printer(hp laser jet 1320) dosen't print correctly in more then 30 pages.
sounds like a memory issues or a windows swap file problem. when printing large docs u need to have some free memory in the computer. Also some printers 2 day used windows memory to print so if your pc only has small amount of free memory it can effect printing out large docs. also with a laptop it shares it memory with the video GPU. so you may need to upgrade your memory in your laptop .
Posted on Sep 25, 2007
md_ehsan_1
  • 255 Answers
SOURCE: Printer installed correctly however will not print.
1. uninstall your printer
2. restart your system
3. re install your printer
4. after installation take a test print
5. hope this will correct your problem..
6. otherwise, run Advance system care to fix your computer problems, such as registry errors etc., due to some registry problem are some other problem in your software makes like this problems.. download from the following link..its a freeware software..download it and install it, Press CARE to start the program.
Advance system care (registry cleaner)
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
Posted on Jun 22, 2009
Josue Pongco
  • 154 Answers
SOURCE: The printer will not respond to computer or print completely
reinstall the driver and check the control panel.
Posted on Sep 23, 2009
  • 22 Answers
SOURCE: installed a printer on a new computer--had no
Open the printer you are talking about in the printers folder or the control panel. Once the window is open click on the "Printer" drop down menu and be sure that "Use Printer Offline" is not checked.
Posted on Mar 02, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: print document system responds document
    A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
    If that doesn't help, try the steps below:
    1. Disconnect the printer from your computer.
    2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
    2. On your computer, go to Control Panel > Printers and Faxes.
    3. Delete the Lexmark print object.
    4. Reboot your pc.
    5. When your pc turns on, reconnect the printer.
    6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
    Posted on Sep 04, 2011
    I've got a document to print and when I click print it tells me (in the jobs queue) it is idle. This has only happened within the last few weeks. How can this be solved?
    Power Cycle the printer sometimes resolved a problem like this.
    Go to printer properties
    right click and choose see whats printing for vista and win7 and click open for windows xp
    pop up window will open then click on printer and cancel all documents
    this will clean documents stuck on queue
    go to start and click search for win7 and vista or click run for win xp
    type services.msc
    pop up window will open then look for print spooler
    click restart on the spooler then it will restart only the print spooler
    try printing again
    Issue
    The solutions in this document address the issue of print jobs getting stuck in the print queue
    A log of print jobs waiting to print
    . The following symptoms might also accompany this issue, and this document does address these other symptoms:
    Printer won't print
    Printer is Offline
    No response from product
    Check the print driver and the port
    If you ever installed more than one HP product on the computer, the product might not be the default printer, or the wrong print driver might have been configured. Follow these steps to check the print driver configuration.
    1.
    On the Windows taskbar, click Start ( ), click Control Panel , and then double-click Printers and Faxes . The Printers and Faxes folder opens.
    2.
    Look for a black checkmark ( ) next to the product icon. This checkmark indicates which product is the default printer.
    Figure 14: Example of default printer icon
    Illustration of the default printer icon in Windows XP
    If the wrong product is the default , right-click the icon for the correct product, and then click Set as Default Printer .
    If the correct product is the default , continue to the next step.
    3.
    Right-click the icon for your product ( ), and then click Properties . The printer Properties window opens.
    4.
    Click the Ports tab.
    5.
    Look for your product under the Description column, and then view the Ports column to the left.
    6.
    Select your connection type to determine which port you should use
    Mar 27, 2011 | Office Equipment & Supplies
    I have just purchased and installed a J3600 Officejet printer. How do I get it to orient the print for a #10 envelope, which has to be fed in lengthwise?
    You'll have to choose "#10 Envelope" as your paper size in whatever program you are printing from.
    Then pick "Landscape" in the print options menu when you go to print on the envelope.
    Apr 15, 2008 | Office Equipment & Supplies
    My Epsom S20 printer takes ages to respond to Word
    Are you using the correct driver for it?
    to find the driver open printers and faxes right click the desired printer, go to properties.
    Click on advanced tab and check the driver there. It should match the model of the printer.
    If it does the driver may be corrupted.
    The uninstall current driver( the install Cd that came with printer should have uninstall option there) then reinstall it again.
    This should fix the problem.
    Nov 01, 2009 | Epson Stylus S20 InkJet Photo Printer...
    Not printing the whole of the page even all in black ink some parts are randomly missing
    Install Temporary Drivers:
    Step one: Install a temporary print driver
    1. On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
    2. Click Add a Printer.
    3. In the Add Printer dialog box, Select USB001 port, and then click Next.
    4. Under Manufacturer, scroll to and click HP.
    5. Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
    6. Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
    7. In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
    8. Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
    9. Click Finish to complete the installation.
    Step two: Designate the temporary print driver for two-sided print jobs
    Follow these steps to use the temporary print driver each time you print a two-sided document.
    1. In the program you are printing from, click File, and then click Print. The Print dialog box opens.
    2. In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
    Aug 18, 2009 | HP PSC 1350 All-In-One Thermal Printer
    HP PSC 1510 All-In-One-Printer not responding
    Normal 0 Driver could be corrupt.
    Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
    Printer is not printing at all
    You may not install the correct driver for the correct OS. Not sure what OS you are using but below link might be useful for you to get the correct driver and install into your PC.
    http://etech.maiila.com/hp-deskjet-3845-driver-manual-software-download-and-troubleshooting-tips
    Hope this helps
    Nov 13, 2008 | HP Deskjet 3845 InkJet Printer
    Printer doesn't respond to computer
    there were many instances why the computer says "printer is not responding" either it is not configured correctly. for a start..
    try this go to start- printer- right click the desired printer- open up properties- then click print test pages-
    if it does print then it should work on all platforms, if it doesnt then you might have installed the wrong drivers.
    try this first
    Jul 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
    Printer won't respond
    1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
    2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
    3. Confirm cancelling all documents.
    4. Right click on the Printer again, and select DELETE.
    1) Click on START, SETTINGS and CONTROL PANEL.
    2) Double click on the SYSTEM folder and select the Device Manager tab.
    3) Click on the "+" for "Universal Serial Bus Controller"
    4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
    5) Disconnect the USB cable and reconnect it.
    Try Printing
    Jun 29, 2008 | Epson Stylus C62 InkJet Printer
    Canon MP810 printer will not print documents, messages come up on screen: printer not responding, printer offline, document failed to print. Other capabilities are fine.
    Hi, there is a possibility that the printer is set off-line or there is a pending print job that was stucked in queue. To check that please go to printer & faxes, right click on the printer icon (your printer), cancel all documents and click yes. Then right click again on the printer icon then select use printer on line. Try printing. If issue still present, restart prinrt spooler services. To access print spooler, goto control panel then administrative tools then select services. Scroll down the vertical scroll bar until select print spooler. Open it then click on stop then start. Try printing again.
    Tirzo
    Jun 12, 2008 | Cannon Office Equipment & Supplies
    Lexmark Z645 InkJet Photo Printer Logo
    78 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
