Tv not working after lamp replacement
6 mo ago tv started shutting off after about 10 min i could turn it back on it would happen every hr or 2 i put a fan blowing on the back and it helped for a while but it shut down completey three lights in front blinking i replaced lamp still wont turn on three lights still blinking in front and no light from new lamp
  • 5,138 Answers
CK Fan if it is going bad set will shut down.
Posted on Feb 07, 2009
Mitsubishi wd-65734 65 in. Tv shuts off on its own and red lamp light comes on. after a few minutes i can turn it back on and works fine for a few min to an hr before doing it again. anyone no wat the...
Same thing on my tv after replacing lamp. Lamp manufacturer advised me that after changing bulb, tv must be reset or tv will go into safety mode and will not turn on. To do this on my model WD-65734 you must hold reset button in with a pen or paperclip for about 10 secs.The LED will start blinking for a few mins. When itstops you need to unplug tv set for about 1 hour. After this the tv will be reset.
Apr 22, 2012 | Mitsubishi WD-65734 65" HDTV
The TV keeps shutting off, then shortly after turns back on, then shuts off again... Plugging the cord into a different wall outlet doesn't solve the problem. Please help! Thank you
I'm having the same problem. My TV will play for for awhile and then it just dims down for about 1 to 2 minutes then powers up again. The green light stays on doesn't blink at all, and there is no red light that comes on or blinks like when our lamp went out. We replaced the lamp about 6 months ago and it's been working great until this week.
Oct 25, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Have a 2002 ion that sometimes wont start but if left for 10 mins will start up.
I have 2003 Saturn Ion. I had this problem over and over 2006 - 2008. IT IS THE IGNITION SWITCH. IT IS DEFECTIVE IN ALL ION'S.The replacement may be defective also, not sure. Mine was driving fine, went ino store for 1 hr came out stone cold dead, would not start and key **** in. Had to have towed to Saturn. They said it was battery and replaced battery.I said this did not make sense. 6 yr battery only 3 yr old , never weak start, never run down, in summer? It happened again 2 mo later. They tried to say battery , I said no. They checked battery. It was fine. Could not find problem. They did total electrical check. It happened again 1 mo later. drove into feed store. Went in came out it happened again. I got jump from someone 30 min later and started right up. 2 wks later same, I got jump 20 min later started. 1 mo late same. Sometimes it would just start up. Took to another Saturn place. They said Ignition switch, saturn was having big problem with this on Ions. Got changed and no problems for 1 yr. I was talking to repesentative at Saturn Headquarters. I told the problem. They said the ignition switch has an electrical component, or it is hooked to electrical component. THEY SAID IF I HAD JUST SAT THERE 20 MIN WITH KEY OFF, THE COMPUTER CHIP FOR IT WOULD HAVE RESET ITSELF WHEN IT COOLED DOWN AND I COULD HAVE STARTED IT EACH TIME. IT WAS BEST TO GET REPLACED AND NOT WORRY, BUT THIS WILL HELP YOU IN A STRESSFUL PINCH, UNTIL YOU CAN GET THE IGNITION SWITCH REPLACED. NOTE: Go to Auto Zone , O 'Reilleys, Pep Boys etc, get a repair manuel , CHILTON $ 23- $ 25 , for your year , make, model car. CHILTON IS MUCH BETTER THAN HAYES MANUEL. It is wonderful and many things you can do yourself.
Feb 09, 2010 | 2003 Saturn ION
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Samsung tv is shutting off all the time.
Do you have enough air flow to cool it?
It may be overheating....add a fan blowing into it and see if that keeps it on.If it does put a strong small computer fan in somewhere to keep it cool.
Aug 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
alecoz@roadrunner.com
Oct 06, 2008 | Mitsubishi WD-62827 62" Television
Projector shuts off sporadically
need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
May 31, 2008 | Sharp XR-10X Multimedia Projector
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
Electro Med Services...
