Question about Canon PC-940 Black and White Copier
Pc940 faded centre
The centre 3 inches of the copies are very faded or missing all together
  • Canon Expert
  • 1,326 Answers
Have you replaced the drum cartridge yet? Or did you and this what you are getting. If the old drum was working ok, but dark. You may have a defective drum unit.
Posted on Feb 08, 2009
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
Toner spots on copies. same location each copy
if the spots stay in the same location, its 100% something on the glass or on the platen cover.
Feb 14, 2015 | Canon Pc940 Alog Copier 13cpm 0008a040
Having reduced 3 inches missing copy print of Legal page (8.5 x 13)
Hi..
me too having same problem in MS Office..but finally i observed sometimes paper sizes or faulty..so try to reduce the paper size..
Apr 05, 2014 | Konica Minolta Bizhub 500...
I have a bizhub 300C. When I print a pdf the top inch is faded
Mike does this happen with all prints? does it go away if you change the orientation of the paper. portrait to landscape? Happen when you copy ? Try different file type does that change?
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
My canon pc940 suddenly prints copies with a dark stripe running down the middle of each page.
On your computer open the menu for your printer. Somewhere there you will find an icon that initiates a cleaning procedure. It usually takes just a few minutes and the printer wil go through the cleaning procedure on its own.
Jan 04, 2013 | Canon PC980 PC920 PC940 PC950 PC960...
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
Copiers
The Ai3010 - fading image at 200,000 copies = needs a new Optical Drum + Cleaning Blade + Main Charger Wire + Developer + Transfer Assembly.
Dec 30, 2008 | Office Equipment & Supplies
Canon PC940 Ticking noise when copying and regestration is off
The waste toner is in the drum unit it's self. If it full you may as well replace the drum unit all togather. Once it is full the drum is just about shoot. If the regestration is off, you may have a problem withe reg. feed clutch. Dose it show up with the paper tray and the manual feed try?
Nov 15, 2008 | Canon PC-940 Black and White Copier
Canon PC940 Problem
You could have a broken exposure lamp. Does the scan bar light up when you make a copy? If not that is the problem. You might also ck the contacts on the machine where they touch the toner cartridge. The toner cartridge opens a shutter to the drum when you slid it into the machine and that may be broken.
Feb 11, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
142 people viewed this question
old marine
old marine
