Question about GE WBSR3140DW Top Load Washer
WHDSR315DDWW, Fills then just sits there and hums.
New washer, no box and no paperwork (sale at retail store). First "trial" wash filled with water and then nothing. You could hear the motor hum... but no action. The water drains and, again, it just hums with no action. Was there something I didn't do? Anybody?
  • 979 Answers
Push down on the agitator. You may have to hold the activating button in with the lid up so you can do this. Press down firmly on the agitator and it should start rotating. If it does, you need to have it replaced. If it doesn't, then let the store know and they should take care of it. You should not put any money into since it is new. Anything you do from this point will cost you some money to fix.
Posted on Feb 07, 2009
My may tag #mvwx655dw1 washer is only 5 months old. The problem is it want fill up with enough water and the sensing light comes and it just sits and hums.
matag is a commercial grade excellent washer
water level sensor faulty
contact point of sale
and see if problem is covered under warranty
Mar 01, 2017 | Washing Machines
Estate Washer Model TAWX700JQ0 Washer fills when started... Does not Wash, Spin, Rinse, or Drain. during the wash cycle the water fill solenoid sounds like it is energized but no water is entering the...
You say washer fills and then you say no water is entering the washer?? Burning smell is most likely motor overheating due to maybe something stuck in drain Pump.
Nov 14, 2017 | Estate TAWX700JQ Top Load Washer
Washer fills, then just hums for about two minuts and shuts down
Hello
The hum sound is coming from the motor that is probably bad and needs replacement. Hope you understand...the washer fills with water which indicates that the control and the water inlet valve are both fine however, as after this you hear a hum sound it means that the motor is bad. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool LSR5132PQ Top Load Washer
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't run
yes at the bottom of washer remove panel shop vac water pump
Feb 01, 2010 | Samsung WF203ANW Front Load Washer
Front Loader Humming
Thats normal just the water valve
Dec 15, 2009 | Samsung WF328AA Front Load Washer
Washer stops at rinse cycle
Hi There,
Sounds like you need a new timer. Hope this helps and thank you for using FixYa!
Mar 30, 2009 | Maytag Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Its fills with water but then sits & hums - dont agitate,drain
It sounds like the controller/timer is bad. If this is an old dial timer type control, can you turn the control and cause the washer to drain? If so, replace the timer control.
If it's an electronic control, then look for a failed sensor as it's very unlikely to be the control.
Jan 15, 2009 | Roper RAX4233PQ Top Load Washer
Year old frigidare washer won't agitate
the selector switch might be out.
Aug 08, 2007 | Frigidaire FWTR445R
GE WBSR3140DW Top Load Washer Logo
193 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
