Question about Acer Aspire 5920-6727 Notebook
Restore problems with acer 5920
Hi, I am trying to re-install my 5920 with recovery disks that I have
for the laptop after a major problem I had yesterday. I cannot access
the pc at all. After running the rescue disks, right at the end, I get
an error message saying 'Restore failed - reason 0xd0000001e. Click OK to restart the computer'. Clicking OK restarts the pc but as it can
find nothing I am at a complete loss as to what to do now or why the
restore disks will not do what they are supposed to. Any help will be
greatly appreciated
  • 458 Answers
Your Restore Partition Has Either Been Altered Or Is Missing....
You Will Need A Full Version Operating System Disk To Install
Posted on Feb 07, 2009
I want to restore my acer aspire 5920 to factory settings without disk.also a toshiba recovery disc was tried so now it thinks its a toshiba. help please
Hi There ,
Try restoring from restore point if possible. You should be able to pick a date and restore. If it came with restore cd or if there is a seprate partition on the hard drive you could also use that...
Hope this helps
Nov 15, 2009 | Acer Aspire 5920-6727 Notebook
I have an ACER Aspire 5920 running Vista, but I have mislaid the recovery disc and the computer no longer boots up. Can I down load Acer Recovery Media onto a disc to boot and repair windows from?
How old is the system? If you have not fully repartitioned & reformatted the drive, you should have an option or prompt while the system boots to either enter setup or a boot menu. If you choose that option {PRESS F8, or some function key}, it will put you at a menu to restore your system.
Most Acers, as well as any major computer companies come with a section of your hard drive set aside with what is called a "flat" of the factory install. This is either a compressed mirror or installation of what was on your system when you first opened the box.
You can find the details for your specific make/model by going to the support section of the acer website.
Oct 07, 2009 | Acer Aspire 5920-6727 Notebook
Laptop does not boot up and recovery from cd gives d2d32 type mismatch error
A couple of things to try in the bios:
1. try changing the SATA mode to IDE for the restore and then back to AHCI mode after it was complete
2. Enable disk to disk recovery mode: To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this
value to Enabled.
Jul 11, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer 5920 Laptop bios problem
it is not possible from crisis recovery disk.You must replace *********** board
Jun 25, 2009 | Acer Aspire 5920-6727 Notebook
Acer asire 5920 wont boot up cant get to windows to type anything in just a black screen asking for password or harddisk password. have acer aspire 5920 system disk it works asks for recovery disk 2 runs a...
For the psswords i can recomend to reset them from BIOS but to do that you must first know them. The problem with recovery disks is solvable if you boot from an XP disc and format the C: partition in NTFS file sistem and when it starts copying files to install the windows stop the installation ( F3 or press the power button for more than 4 seconds.. don't worry you will not sustain disk damage... done it myself with the same notebook for a dozen times ) After formatting the partition C: try recovery again and it will work.
NOTE: for the formatting of the partition you must set the HDD mode from AHCI to ATA witch permits the XP setup utility to "see" the HDD. If it is set in AHCI mode the setup utility for windows XP will not detect youre HDD
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Unit is still under warranty. Acer Aspire 5920 home theatre. Keeps freezing while on internet. want to clear system & reset computer,
has this problem started recently or been impacting you for a long time?
If it's a short-term issue then rolling back to a time period prior to the error occurring is usually the quickest way of fixing the problem (could have been caused by a number of issues e.g. conflicts in the registry or files corrupted). In order to rollback got to Control Panel\Backup and Restore Center and select the date of the most appropriate restore point.
You could also try downloading the latest version of the software that is causing the issue from the aspire website-
If the above fails complete a fresh install-
Acer supply good quality system recovery and software installation disks with all new laptops.
Ensure you have backed up all your data and any programs that you don't have on disk onto a USB memory stick or similar.
Locate your recovery disk and insert into the DVD drive. Restart the laptop and follow the on-screen instructions to complete a fresh install.
// j
Jun 04, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 - Acer Arcade Deluxe Problem
have you checked your bios settings are you booting from the right drive have you tried recovery?
Jun 02, 2009 | Acer Aspire 5920-6727 Notebook
Restore window vista for acer aspire 5920
Hi Acer supply the restoration files in a hidden partition on your hard drive. If it is the same as mine try this. Start the pc, then while the Acer logo is showing, press ALT & F10 at the same time. Then just follow the instructions. Bear in mind that this will format your C drive so you should do a backup of any important data first. Hope this helps.
Sep 27, 2008 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 laptop, cannot invoke Alt-F10 when booting initially
just press alt f10 ONLY when you see acer logo on boot and hold for a sec i had the same problem and its all adout timming hope i help...
my acer a0751h
Feb 14, 2008 | Computers & Internet
Restore to factory default
Perform a system recovery:
Acer computer's do not ship with recovery CD's - there is a program that allows you to burn the disks or recover.
3 ways to recover:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of Restore
3. If unable to boot into Windows then tap Alt/F10 during boot right after Acer splash screen when starting up the computer.
4. This will start the Acer E-recovery program - choose Factory Default Settings and follow instructions.
For Acer end user technical support, spare parts and service: 1.800.816.2237
Dec 16, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5920-6727 Notebook Logo
193 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
