Back to:
Tags:
Gateway 300 C PC Desktop
Odd crash problem
By Horner - usenet poster
Or you can still build a modern 'low power' machine with a Celeron M or
similar chip. It isn't exactly a laggard as it has 1GB RAM, 1MB cache and
still drives my 20W TFT 1680x1050 over a KVM with no problems. But it
is of course an extra expense, but IMO well worth while having things
separate.
The internet will never be totally secure. This is because the internet
is an anonymous world where someone can and will try it on. Computer
systems were never build to resist malicious attacks, only to be fairly
resistant to benign attacks, e.g. mistakes by people working in common.
The internet is not such a benign place.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Bray
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The message < from John Jordan <
Actually, that prompts me to chip in with a piece of data from the
Samsung web site regarding the temperature limits for their Spinpoint
series of hard drives.
Samsung specified it as a temperature range expressing it as "5 to 55
deg C is the optimal range". My first thought on reading this was "What!
_All_ of it is optimal?". It would seem the google survey results lend
some credence to this claim. :-) Mind you, exceed the upper limit of
this 'optimal' range by just a degree or two for just an hour or two,
and you're in danger of suffering terminal data loss (as I found to my
cost a couple of years back).
I couldn't agree more! You'd do far better to use one of those 'spot
mounted' fans to redirect a cooling draught of air over the dimm slots
from a cooler part of the case interior and leave the heat spreaders in
their packaging on account they'd shield the module's PCB and ancilliary
components from said cooling draught.
If necessary, fit a deflector (stiff cardboard) to prevent the warm
exhaust from the CPU cooler spoiling the cooling airflow (unless the cpu
fan has been reversed to allow it to exhaust its heat load directly into
the PSU vent slots or via ducting to a case exhaust port :-).
Regards, John.
Please remove the "ohggcyht" before replying.
The address has been munged to reject Spam-bots.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Odd crash problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Ranny
Rating: 0%, 0 votes
It's certainly a flawed study, what with the unspecified mixture of
drive models and environmental conditions. On the other hand, the
temperature conclusion isn't implausible or unlikely, and I haven't seen
any conflicting evidence anywhere else. Unlike electronics, mechanical
devices generally do have an ideal operating temperature.
Well, unless they have significantly more surface area than the chips,
they're not likely to radiate or conduct heat much better. The thermal
pads will act as an insulating layer, hence the inferior overall
performance.
Ideally you'd have finned heatsinks and proper chip- in most cases, RAM heatspreaders appear to be just aesthetic.
John Jordan
Thank You!
Solution #3
Not Rated (0)
Chandler
Rating: 0%, 0 votes
That is quiet :)
*gasp*! Shut it down?! Never. It runs 24/7/365. I'm firmly in the
camp of "it's better for the hardware if it's left on all the time".
But that's the subject of religious wars and best left to a thread of
its own :)
Just don't ask me about my electricity bill.
Understood.
Absolutely. I wasn't trying to suggest that it was inappropriate.
Well, again, we know it's "big numbers" marketing aimed at a certain
subset of PC users.
Yes. I put mine in 5.25" to 3.5" adapter cradles in spare 5.25" bays.
This gives them plenty of room to breathe. The adapters have a
ventilated front bezel which allows air to enter and flow over the
drive. I can tell it works, 'cos when I took a drive out a couple of
days ago, there was dust on it in the same pattern as the vent slots.
*nods* Very much agreed - but remember you're the one that went through
several DIMMs until you found a pair that met your requirements :)
Online reviews are useful for identifying a suitable case.
Sure. Horses for courses, each to his own, etc. It's interesting to
compare and contrast our differing approaches to the subject, though.
I did intend this to be discussion, not advocacy - just want to make
sure you understand that.
(\__/) Bunny says NO to Windows Vista!
(")_(")
Thank You!
Solution #4
Not Rated (0)
Joey2
Rating: 0%, 0 votes
Yes, I've read it ("Failure Trends in a Large Disk Drive Population")
carefully. There's a printed copy sitting by my elbow as I type this.
It's flawed and I don't agree with some of the methodology or findings.
It came in for some criticism on comp.sys.ibm.pc.hardware.storage.
IMO, if the authors had had the nerve to publish failure rates indexed
by drive maker, the survey would have carried more weight. They were
probably too concerned about being sued, though, especially as it
doesn't seem to be an "official" Google publication.
Heat transfer pads between the memory chips and the metal of the
heatspreader, then clips to hold the two halves of the heatspreader in
place.
It's interesting how the makers refer to them as "heatspreaders" rather
than "heatsinks", don't you think? Especially as that's exactly what
they appear to do.
(")_(")
Thank You!
Solution #5
Not Rated (0)
Charlie
Rating: 0%, 0 votes
The message <oCMZU0Bn+ from Mike Tomlinson <
I think the psus with interior mounted fans work best when the fan is
mounted 'outboard' of the psu casing. This reduces the resultant
turbulence (and loss of efficiency) somewhat.
The small 150 watt unit in the Gateway 2000 case that houses my FreeNAS
4 disk drive server has its interior mounted 80mm fan mounted 'outboard'
of the psu casing (right next to the CPU socket, as it happens :-). The
only mods I did with this was to add a 3.3v zenner to the fan speed
control cct to raise the minimum fan speed a little and twist the
exterior vent slots to about a 45 deg angle to reduce turbulence and
increase the effective CSA.
This fileserver origionally had a super socket 7 MoBo with a K6/2/500
underclocked to 250MHz and undervolted to 1.35v to keep the whole power
consumption down to 50 watts. I had to use the spare KT600 MoBo and
XP2500+ cpu as an upgrade on account the Gigabit network adapter upgrade
was being throttled by that old MoBo.
I've configured the CPU to run at 665MHz instead of the normal 1836MHz
and this has allowed me to set the minimum core voltage setting of 1.1v
(even this amount of cpu 'horsepower' is gross 'overkill' for a
fileserver box). In spite of the huge drop in cpu power consumption, the
box now uses 20 watts more power, all for the priviledge of getting a
useful boost of network speed out of my Gigabit upgrade.
Although you might consider a small 150 W ATX PSU to be marginal for a
box with 4 hard disk drives, it seems to cope just fine in spite of the
fact that the spin up surge at startup does top the 150 watt mark.
I origionally picked the Gateway 2000 box to house my fileserver on
account of its more efficient and remarkably quiet PSU. This box is
still so quiet that you need to place your ear within inches of the vent
slots to hear anything at all whilst my reasonably quiet desktop machine
is running. In the dead of night when everything else is switched off,
it's just possible to hear it running if you stand close and 'listen'
very carefully'.
You might think that a constant background noise is of no significance
but, if you feel any sense of relief on shutting your PC down at the end
of a session, then it's significant enough to be a source of stress that
warrants some attention.
Even as quiet as my own PC is, I still feel a _mild_ sense of relief
when I shut it down at the end of the day (often, this is in the quiet
hours of the morning, around 3 am, so the contrast is magnified by the
almost utter silence of my nearly silent fileserver).
To give you some idea how quiet my PC is, I can tell you that even the
quieter examples of customers' PCs usually totally drown out the noise
it generates. I have on very rare occasions had the pleasure of working
on extremely quiet machines which don't drown out the noise from my own
PC, but this situation is exceptionally rare.
Many of the PCs I have in for repair have been so noisy, I wonder how
their owners can tolerate them for any lengh of time, especially if I've
had to run chkdsk /r from the recovery console for the, typically.
couple of hours this usually requires. When I've finally finished
working on _these_ machines, it's an absolute joy to shut them down and
return to tranquility once again.
It wasn't the clock speed being reduced, it was one of the other timing
parameters that created a reduced "benchmark" reading in memtest86's
information panel.
I don't think a single 2GB dimm would necessarily get round the
problem, plus, AFAIR, 1GB is the limit per slot. Even if a 2GB dimm was
an option, I still wouldn't choose to invest in what, even by then, was
becoming an obsolescent technology.
True, but this is uk.comp.homebuilt so an appropriate comment.
I'm nothing if not pragmatic. :-)
That might be the peak (or, being generous, the short term max loading)
rating but I doubt such PSUs could sustain half that loading
indefinitely or even that any PC system box so fitted would peak much
above 300 watts.
Any PC that demands more than 200 watt will be quite noisy even when a
'quiet' design of fan cooling is employed.
You're quite right about considering the cooling requirements of the
hard disks. A lot of the 'traditional case designs simply leave this to
chance and, as you mentioned, compound the issue by having hard disk
drive bays that force the two drives into very close proximity.
I agree that you don't need massive flows of cooling air to keep a
drive comfortably cool, just at least 2 cms of airspace both above and
below each drive for the air to flow, unobstructed past each drive.
The four drives in my file server rely purely on the air passing them
from the ventillation holes drilled into the front of the metal case
through to the CPU heatsink fins and into the PSU fan at the rear of the
case.
The original hard drive bay does present a problem in that it does
stack the two drives a little too ...
read more »
Thank You!
Solution #6
Not Rated (0)
Melissa
Rating: 0%, 0 votes
Gas is about 1/4 of the price of electricity per kWh, although it does
get interesting if you're only trying to heat one room.
There was just a lack of demand, IIRC. BTX has a problem where you lose
a large chunk of drive-bay space, and needs chipsets flipped to get the
lines the right way around, all for a problem that no longer exists
(120W+ CPUs).
Dell do use BTX, which makes sense as they always built single-fan
ducted systems, and BTX is better for these if you have a mid-range+
video card. Not sure about anyone else.
Note that the Google hard drive survey showed the best reliability at
35-40C, with a rapidly escalating failure rate below that range.
What did you use to attach the heatspreaders?
John Jordan
Thank You!
Can you Help with these PC Desktops problems?
PC Desktops
when you turn tv on in the morning it is all fuzzy for...
PC Desktops
i tried to install prison tycoon 3 lockdown on my computer...
PC Desktops
what is your hobby?
PC Desktops
using acer aspire 5920 and touchpad has stopped working...
PC Desktops
Cant find Swann usb 2 0 dvr guardian mdl sw241 ud4 free...
Loading problems.
Repair Service
Find PC Desktop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
