Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Green lamp is out.
I have acquired this T.V. and after taking it apart I found out that the middle green bulb (or whatever it is called) is out. I made the mistake of trying to remove the lens and spilled some of the liquid. Anyways, my main problem is to figure out from easiest to hardest what is wrong. If it is the bulb I have no idea how to get to it. If anyone can help I would greatly appreciate it.
  • 4,234 Answers
The part you are referring to is a CRT. These are not cheap and may no longer be available. There are kits for replacing the fluid, but it is not the type of job I would recommend for an inexperienced person. Also, it is not likely that the CRT is the problem. There are circuits that drive the CRT that could be the problem. At this point, I would recommend you invest in a detailed repair estimate. Using that info, we should be able to guide you through the actual repair.
Dan
Posted on Feb 07, 2009
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
My Epson PowerLite 1725 projector has a wide green bar displayed in the middle of the screen with a purple shadow on its right. Do you think a bulb replacement would fix it?
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
Mar 05, 2011 | Canon LV-LP12 Projector Lamp for LV-S1,...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
When I power up the projector the center of the image is GreenThe projector has a new lamp. Is it the power supply?
This problem is more likely to be the Green LCD gone. The green LCD's job is to filter out the green on the picture where it isn't necessary so If the green LCD starts to fail, it will let through too much green light. I think its more in the middle because of the heat from the bulb over time.
Oct 23, 2009 | Sony VPL HS10 Multimedia Projector
HITACHI 51F510 MIDDLE PROJECTION LAMP
The small pcb that is hook up to that middle crt (lamp as you call it) should be pushed up tight on to the crt (also called green pichure tube). The wires that are on that small board should also be pushed on to make sure they are seated tightly. If none of this works, then take to a repair shop.
Sep 26, 2008 | Hitachi 51F510 51" Rear Projection...
I have 2 panasonic tv's now have both green and blue spots present
Call Panasonic and they will schedule this problem to be corrected in home and pay for it.
Sep 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Samsung TV about 4 years old, the tv turned off by itself last night and for whatever reason will not turn back on. When we use the remote the middle green light comes on in the middle as well when we use...
have u repleace the lamp yet , if not repleace, 4 years old would be a lot of hours the lamp may look intact but after severals hours tv start to go off
May 03, 2008 | Televison & Video
Green bulb for projection tv
I found the lamps at PartStore.com for $146 plus ship/hand/taxes
Feb 02, 2008 | Sony KP-53HS10 TV
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
97 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
