Question about Power Acoustik GOTHIC OV2-1200 Car Audio Amplifier
My amp goes in protect mode
I have a power acoustik 5500d reactor series.it is brand new.i have already unhooked everything and hooked power and ground and remote wire.PLEASE HELP!!!!!!!!
  • Anonymous Mar 15, 2014
    when I only hook up power , remote, and ground wire a.p goes In protect mode
    Genius:
  • 1,550 Answers
Maybe the audio amplifier IC´s are damaged
Posted on Feb 07, 2009
Amp has power but wont play music and its not in protect mode
Is your gain turned up on the amp????? Is you preout turned on in the settings on your stereo????? Maybe temporarily run an extra rca cable to see if thats the problem.......Are you running one sub or two????? Did the amp work before?????
Apr 13, 2012 | Power Acoustik OVN1-5500D Car Amp
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2011 | Power Acoustik LT-980/2 Car Audio...
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
My amp is flashing in and out of protect
you must likey just fryed the wires, try putting in bigger fuses, and unhooking everything and re hooking it up
Jun 13, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
I have a power acoustik ps2-2600 it went out this morning the red light was on i checked the ground it was fine when i unhook the remote or the audio cables it turns off if i hook up the audio alone it...
unhook all the cables including power let sit for 15 minutes and than hook up the ground rca cables remote and than power in that order with the car off and the battery unhooked that hook the battery up the amp went to protect mode to keep it from blowing i hope your amp isnt like some that only the factory can reset most amps arent and reset themselves
Apr 20, 2009 | Car Audio & Video
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Power Acoustik TS620-2 Amplifier
Check the wiring at the speakers themselves. It's possible that while you were moving the box one of the speaker wires came loose and shorted against the other terminal. A shorted speaker wire or damaged speaker will cause the amplifier to go into protect mode. If you have a digital multimeter with a resistance feature, you can test the resistance between the positive and negative terminals for each speaker.
Feb 26, 2007 | Power Acoustik TS620-2 Car Audio Amplifier
Power Acoustik GOTHIC OV2-1200 Car Audio Amplifier Logo
311 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
