My Jag wont turn over & I dont think its the battery. I did disconnect it & charge it all day then it started up after a few turns & now wont start again. I wondering if there is a way to get the codes before I do spend all that money on a new battery.
Something wrong here .. battery tests good and starter tests good and it wont spin the engine over. ok what if you jump start it ? if it spins the engine the battery is shot.. if the starter is spinning and not turning the engine the starter or selonoid is bad .. thats got to be all there is to it .. thanks again Jerry
Hi
Classic faulty battery symptoms.
Expect it´s the original ...... 6yrs old ?
Get a new battery and go from there !
Good Luck !
A FixYa rating would be appreciated thanks !
John.
I checked the battery after I gave it a good charge & ot says the battery is ok. Everything else works, the heat, ac, lights, radio & it just wont start. I did check the fuses also so thats why i was looking for a way how to pull the code.
It did start few months ago but then wouldnt after that last charge.
Yes it has gas.
Thanks for the help guys.
I was reading somewhere online last night & I think It might be the starter because someone else has this same problem... "clicks from what I think may be the selinoid engaging but the engine will not turn over. When I release the key there is a 1 to 2 second winding down buzzing sound. "
Same problem as me I believe. I will charge up the battery again while I attempt to remove the starter & see what happens from there.
I will keep you guys posted. Thank you for the help!
I took out the starter & had it checked at AutoZone & they said the starter was OK. Put it back in & still does the same as before. The battery says its ok also but still same sound happening.
Yes the starter spins & engages when they tested it. I put it back in & still doesnt turn the engine. The battery is reading that it is good when checked with the meter.
I did try to jump start it & same thing, nothing. I also charged the battery all day a few weeks ago & thats when it did start up but then after trying again, there was nothing just same clicking sound.
Yes it does not spin the engine but when I tried to jump the starter yesterday with a screwdriver touching the starter terminals, it did try to turn the engine like 2 inches very slowly. Maybe the battery really is shot. I think I will just go spend the 140 for a new battery & hope that is the problem. I will wait till Friday for that & keep trying a few other things.
I think I will also doubble check all the fuses.
Hey guys, Sorry I havent posted this sooner but you know what I did. I went out & bought a new battery anyway & that was the problem, starts right up. They said the stock battery wasnt meant to be charged up so maybe when I did charge it that first time, that was the only time it would take a charge & destroyed itself.
When you took the starter to the parts store did they say the solonoid was working properly ?? you already said it was winding down so I assumed you ment the starter spins .. It has to also spin when it is engaged by the solonoid into the gears to turn the engine over .. Jerry
Now you told the whole story with the spinning noise and winding down your starter is turning over but it is not engaging.. it is the solonoid which engages the starter to turn the engine over. it is sticking and wont engage..the solonoid is it..
Tell me more on the problem will the engine spin over but just wont start ? if it does you need to shoot a little starting fluid into the throttle body throat or in the air cleaner or use gasoline to see if it will try to start or start up .. if it does you have a fuel problem if not let me know we wil go from there. thanks again Jerry holler if you need more.
Sounds like a battery to me has a friend got a battery tester you can borrow ? you charget it up good and then use the tester .. to see how it acts when you pull a load on it with the tester . Jerry holler if you need more.
