Question about Acer Computers & Internet
  • 2 more comments
  • melaniebovin Feb 06, 2009
    device manager says it is working OK, the wireless connection is showing as disabled, when I try to enable it,it starts but remains disabled, keeps saying it needs connectivity, but I have the wireless LAN enabled
  • melaniebovin Feb 07, 2009
    Yes, that is enabled.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Check to see if the wireless connection is enabled in your router.
  • Ben Wabnick
    Have you checked the device manager to see if the driver for your wireless card is installed? I ran into one that I couldn't enable and it turned out to be the network controller drivers were missing, check that and let me know.
  • 191 Answers
You need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Posted on Feb 09, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    missstake one word: 2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light is on.
  • Frank Zhang
    Frank Zhang Feb 12, 2009
    is this helpful please feedback thanks
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
Hi could you tell me please how i set up a wireless connection on my bt home hub thanks
First you will need a wireless router.Once you have this you will need to take a conection from the existing hub to use as a source for the internet.Configure the router as per instruction.
Good Luck
Oct 17, 2009 | Computers & Internet
I have a BT 2-wire hub with networked printer.
First thing, Does your printer have a wireless facility built in? If not it has to be connected to the hub with ethernet.
Normally setting up a wireless printer involves using cables until the set-up is complete. It's nothing to do with the router but all to do with the printer.
Best thing is to go through the manual.
Oct 14, 2009 | 2wire (1000-400108-001) Router
My Belkin 802.11g Wireless Desktop Network Card keeps dropping its connection. This happens every minute or so at present. Signal strenght to BT Home hub is strong (four bars) and drivers are up to date....
Sounds like you need to re-sync your modem and router. Remove the power plug from the modem and router. Then first plug the modem power on and wait for all the lights to come on. Then plug the power to the router and wait for all the lights to come on. Re-start your PC and see if it is ok. Good Luck.
Jul 29, 2009 | Belkin 802.11g Wireless Desktop Network...
Wireless G Desktop Card Connection to BTHome Wireless Router
uninstall the bt desk top help first then the bt wireless connection , if ur wireless card has an utility use it to configure . the connection might be due the conflict between the wireless software. checked if ur getting limited or no connectivty if so delte and recreate  the wireless profile, if ur using bt router like home hub or voyager go the router page with the ip for hub its and navigate to advance and keep the wireless channel to 9 or 11  for voyager the its
Oct 21, 2008 | Belkin 802.11g Wireless Desktop Network...
Computers & Internet Logo
1,997 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
