Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Bosch Logixx 8 error F 34
When I try to start a wash cycle I get the machine beeping and displaying error f:34
What does this mean?
Is it stuffed?
Thanks Mark
  • 1 more comment
  • Anonymous Apr 02, 2009
    I have the same problem. any luck?
  • Anonymous Apr 04, 2009
    I'm too. And I'have just buyed it.
  • Anonymous May 08, 2009
    same problem.
3 Suggested Answers
dr appliance
  • 266 Answers
SOURCE: Bosch Logixx 8 Fabric conditioner not releasing
REMOVE TOP CABINET LID MAKESURE DISPENSOR MOTOR IS ROTATING TO RINSE OUT DETERGENT COUP IF IS AND NO WATER IS GOING IN THEN REPLACE WATERVALVE ,, IF WATER IS GETTING TO DETERGENT CUP FOR FABRIC SOFTNER TRY REMOVEING DETERGENT DISPENSOR AND CLEANING DETERGENT CUP
Posted on Jan 24, 2011
blueextc3221
  • 15935 Answers
SOURCE: My Bosch washing machine (logixx
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
  • 6277 Answers
SOURCE: I have a Bosch Logixx
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Sep 15, 2011
Testimonial: "Thanks - the engineer is coming later today. "
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
Bosch exxcel washing machine
try checking/replacing the inlet water valve. hope this helps
Nov 24, 2013 | Washing Machines
Logixx 8 beeps at the end of the wash cycle
Start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now.
Oct 21, 2012 | Washing Machines
How do I stop my Bosch logixx 8 from beeping endlessly at the end of a cycle?
hi, I found out last night after being wokenup by endless beeping.... start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now....
May 09, 2012 | Washing Machines
I have a Bosch Logixx 8 washing machine showing error code 34. What does this mean?
John C
Sep 15, 2011 | Bosch Washing Machines
Hi How do you remove the child lock on a Bosch Front loading washing machine Logixx 8
Hi
Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Thanks for contacting fixya.com
Nov 13, 2009 | Bosch Washing Machines
My Bosch washing machine (logixx 8) shows error code F37 and beeps
Jan 06, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
2,575 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Richard Roth
Richard Roth
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
