Question about Microwave Ovens
I have a frigidaire gallery microwave and it will not heat
I have a frigidaire gallery microwace and it will not heat. It turns, lights, but it will not cook or heat at all
  • craig pursloe
    craig pursloe May 11, 2010
    hi there this sounds like a tricky problem can i ask does the microwave have a heat setting swtich and if so is it a dial or do you have to program it in? aslos can i have the model number from the back of the unit thanks
  • Microwave Ovens Master
  • 9,098 Answers
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I have a frigidaire gallery microwave and it will  - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here or here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Feb 15, 2009
I don't know why my frigidaire gallery microwave FMT118EPB goes on but doesn't heat
the magnitron supply EHT isnt there
or the heaters connections inside the square metal box
have come loose
replace the magnitron is best and check the eht fuse {inline type usually}
Aug 13, 2014 | Microwave Ovens
Frigidaire microwave
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
Frigidaire Gallery Microwave making a new
If this is new, return to the place of purchase, causes, defective magnetron, bad inverter board, and possibly keypad control board.
May 20, 2012 | Frigidaire FGMV185K Microwave Oven
Frigidaire Gallery stovetop model number LGEF3031KMB Oven will not heat up to temperature. Oven, Pre-heat lights will come on, but the oven will not reach any temperature set.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 11, 2011 | Microwave Ovens
Frigidaire microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=--=-=
May 19, 2010 | Frigidaire FMT148G1 Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
Frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Mar 04, 2009 | Frigidaire FMT116E1B Microwave Oven
Cookworks microwave not heating up
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If for some reason you don't have your owner's manual, I would suggest calling the dealer where you bought it to see if they have a number for Cookworks.
Jan 04, 2009 | Emerson Black Microwave Oven
Microwave Ovens Logo
134 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
