Nostalgia Electrics PCM805 Hard CandySugar Free Cotton Candy Maker Logo
A
Anonymous Posted on Feb 09, 2013
My cotton candy machine won't heat up
We have used the machine a few times, and it worked beautifully. but then today it just stopped heating up. we had made a few already, so whats wrong with it
1 Related Answer
Lance Hill
  • 1739 Answers
  • Posted on Aug 14, 2011
SOURCE: lost and need instuctions for cotton candy machine
The Instructions and Recipes for your Nostalgia Hard & Sugar Free Cotton Candy Maker PCM805 can be found here:
http://nostalgiaelectrics.com/manuals/pcm805.pdf
Thank you for using FixYa!
Please my candy cotton machine is melting sugar but the sugar isn't giving out candy but rather getting burn and smoking. What can I do?
Residue builds up from multiple uses of the machine. That residue near or on the heating element begins to burn. https://www.searanchlodge.com/how-to-clean-cotton-candy-machine/
Check the website associated with your brand of machine to see if it offers any particular disassembly instructions or cleaning tip. However, the above cleaning instructions may suffice.
tip
Be the cotton candy maker!
Here is how to operate a professional cotton candy machine.
First of all make sure you are renting the machine from a reputable company and that it arrives with a trained professional who knows how to operate it properly.
Also make sure that the machine is on a steady base and that no children or animals can get too close.
It is best to use a plug just for the machine instead of sharing it with other appliances.
To begin, turn on the machine's main power switch and fill the floss head with sugar.
It is very important not to fill the head above 90%.
Turn the machine's motor and then the heat switch on, putting the head dial setting on HIGH.
The sugar will start forming in about 45-60 seconds.
When the cotton candy starts pouring out you should have your cone ready. Dip it in the machine and pick the cotton candy by giving the cone a twirl that will gather the sugar around the cone.
Avoid rolling the cone around in circles as it is not the correct method to gather cotton candy.
When you are done, first of all turn off the HEAT and allow the motor to continue running at least 45 seconds, in order to get rid of the leftover sugar, and cool down the heating element.
Than disconnect the stabilizer screen and clips, rinsing them in warm water to dissolve the sugar.
You can now remove the floss pan from the main unit and rinse it off.
Children must not play with the cotton candy machine. It certainly is fun but it is not a toy.
1helpful
My cotton candy maker dose not work and it has been two years! It's too late to return it now and I can't throw it away! what can I do! I wasted 30 bucks for this piece of junk! Help me fix it please!
With any device, it is helpful to know the brand and model number. I will provide a few links to some cotton candy maker's repairs but you have left out the crucial information. Not to worry. You can google "cotton candy maker" the brand and repair and possibly find some information. Even better, you don't have to have the machine to make cotton candy. I will provide links to that as well.
Make homemade cotton candy without machine
http://www.sheknows.com/parenting/articles/992989/make-homemade-cotton-candy
How to Repair My Tornado Cotton Candy Machine
Cotton Candy Machine Out Of Balance Ideas
Repair your Popcorn Machine Cotton Candy Machine Nacho Machine...
My crazart cotton candy maker won't produce the cottan candy anymore.Had it since Nov. and used it multiple times since.All of a sudden I plug it up I pour the sugar In and no cottn candy comes out
If your Crazart cotton candy maker is no longer producing cotton candy, there could be a few potential issues to consider. Here are some steps you can take to troubleshoot the problem:
  1. Check the power supply: Make sure that the machine is properly plugged in and that the outlet is functioning properly. You may also want to check the fuse or circuit breaker to ensure that the machine is getting the proper power supply.
  2. Check the heating element: If the heating element on the machine is not functioning properly, it may be preventing the machine from producing cotton candy. You may need to replace the heating element to fix the issue.
  3. Check the spinning head: If the spinning head on the machine is not functioning properly, it may not be able to spin the sugar into cotton candy. You may need to replace the spinning head to fix the issue.
  4. Check the floss bucket: If the floss bucket on the machine is not properly seated or is damaged, it may be preventing the machine from producing cotton candy. Make sure that the floss bucket is properly seated and check for any visible damage.
If none of these steps resolve the issue, it is possible that there is a deeper malfunction or defect with the machine that will need to be addressed by a professional. In this case, you may want to consider contacting the manufacturer or a customer service representative for further assistance.
Our cotton candy machine over heated or something, but it won't come back on. Any suggestions of what might be wrong with it?
It could be the thermostatic temperature control. Most electrical heating devices also have a little fusible overload that senses both over temperature and over current; they look like the one on the link
Thermal Fuse 128 Degrees Celsius
They are often hidden in a fiberglass or teflon sleeve to spread out the heat a bit.
It could be the heating element itself or the cord to the unit
1helpful
Help fix cotton candy machine
The lighter wires from the transformer, black attaches to terminal 4, (this will have many other wires attached, and can be more than one terminal labeled #4) The red from transformer attaches to #3, it will be the only wire on a #3 terminal.
The heavier red wire most likely goes thru the back wall to the brushes, and attaches to a #4 terminal also. They have used different heat controls over the years, so this diagram may not exactly match your machine, the the terminal numbers are consistant.
1helpful
Hi , I recently purchased your machine and would like to know how to flavour and colour the cotton candy. I did not receive any sugar in the box , so I'm not sure what to use. Please help. P.S - Can I...
Hi pandoramagic...
This is not the company that you bought your machine from, it is an "Answer Company" we supply answers to questions people have.
You need a special sugar in the machine (read below), and you can use liquid food coloring to color the sugar/cotton candy and different liquid flavors to flavor the cotton candy.
Typical machines used to make cotton candy include a spinning head enclosing a small "sugar reserve" bowl into which a charge of granulated, colored sugar (or separate sugar and food coloring) is poured. Heaters near the rim of the head melt the sugar, which is squeezed out through tiny holes by centrifugal force. Precolored sugar packaged specially for the process is milled with melting characteristics and a crystal size optimized for the head and heated holes; granulated sugar used in baking contains fine crystals which spin out unmelted, while rock sugar crystals are too large to properly contact the heater, slowing the production of floss.
The molten sugar solidifies in the air and is caught in a larger bowl which totally surrounds the spinning head. Left to operate for a period, the cottonlike product builds up on the inside walls of the larger bowl, at which point the machine operator twirls a stick, cone, or their hands around the rim of the large catching bowl, gathering the sugar strands into portions which are served on stick or cone, or in plastic bags. As the sugar reserve bowl empties, the operator recharges it with more feedstock. The product is sensitive to humidity, and in humid summer locales, the process can be messy and sticky.
Webpage for cotton candy supplies: http://www.epopcorn.com/cotton-candy-machines-cotton-candy-supplies.html
Please take time to rate me
Have used cottonwoods on smokey joe twice now and each time the briquettes have lost their heat within minutes. Tried using the Weber rapid lighter and they heated up beautifully but as soon as they were...
I've only used Cotton Wood twice. The first time, I had the same experience. The second time, I added a few pieces of all natural, lump charcoal and it kept the Cotton Wood burning at the proper temperature. I suspect the same procedure will work for you.
Happy Grilling!!
2answers
I need a replacement extractor head for my Nostilaga Cotton Candy Machine, model CCM-527. Where can I purchase one?
i need a replacement for my nostilaga cotton candy machine model ccm 527 where can i purchase one
Top Nostalgia Kitchen Appliances - Others Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Nostalgia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
