Question about APC Heating & Cooling
No power,celestial kfr70gw airconditioner doesnt have any power
Was working then stopped no power to head unit does this model have a reset button or inbuilt fuse?
  • 230 Answers
SOURCE: my problem is with frigidaire
I am not too familiar with these systems but, it sounds to me like it may be in a safety lock out mode.
Possible failures:
Fusible link
on board Surge protector
faulty circuit board
Posted on Jun 17, 2008
louislevel_2
  • 374 Answers
SOURCE: Split system Celestial turn off for a while when
Turn off while running and then turn back on again, causes electrical control circuit system was malfunctioning due to overload relay trip off and then this will trigger on when the load was cold setting the unit run again.Overload tripping off due to there's a high current flowing in the circuit w/c is higher than the rated current specified in the unit.Several factors may be consider the head unit is developing hi pressure that causes electrical circuit malfunction.or the thermostat is defective or some thermostatic valve is mulfunctioning.
Posted on Mar 01, 2009
  • 358 Answers
SOURCE: Hitachi RAS 5142CHA Won't operate
Check the fuse on the control board inside the head unit,if its ok you need to replace the contrl board
Posted on Apr 04, 2009
AJIN G
  • 6694 Answers
SOURCE: Weathermaker Airconditioner.Model No.S18HF-1.Split System While
hi,
Check the circuit board inside the indoor unit. Some time moisture in this circuit board can miss lead the functions of the board. Heat the board with hairdryer . Also check the coil sensors and the Room temparature sensor Connected to the board. If any one is faulty this type of problem can occure. Remove the two sensors and check the value of the same witha an OHM meter. The two sensors will have the same vaule at room temparature.
ok
Posted on Jul 30, 2011
ercupa190
  • 12223 Answers
SOURCE: Fujitsu airconditioner multihead c notworking
Dear Sir:
If your condensing unit has coils that are bent, they should be straightened out as much as possible for proper performance of the unit. You cannot straighten the fins properly without a special tool called a fin comb. These tools come in a variety of styles including single, multiple or interchangeable heads having different fin comb sizes and counts to best match the coil fin size of the repaired unit
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Posted on Mar 29, 2012
What is error code 5200 mean?
Is this a Canon printer? Which model do you have? On some, the 5200 error indicates that the print head has overheated. You should turn off the printer. Then unplug it for a while (possibly 5-10+ minutes). I'd recommend unplugging the cord from both the wall outlet and the printer itself, if possible. Then reconnect the power cord and test turning on the printer.
On some Canon printers, remove the ink cartridges and the print head (if it is removable). Then restart the printer and install the print head and cartridges when the printer requests the ink.
You can also try resetting the printer's internal fault memory.
On some models, turn off the printer. Then
1) Press and hold the Stop button.
2) Press the On button and hold that.
3) Release the Stop button.
4) Press the Stop button 5 times. Release both the Stop and On buttons.
5) The LED will blank while the unit resets. (If your computer is connected to the printer via a USB cable, the computer may indicate new hardware found.
6) Turn off the printer and then turn it back on.
Other models:
1) Press and hold the Reset button while pressing the On button.
2) Release the Reset button while still holding the On button down.
3) Press Reset twice.
4) Release the On button.
5) The LED should blink with a 0 in the window.
6) Press Reset 4 times and then press On twice.
7) The printer should turn off.
8) Turn the printer on.
If these steps don't work, the print head or the electronics inside the printer need to be replaced. If the unit is under warranty, contact the manufacturer. Note: if you get a replacement print head, you can not return it for a refund once you install it. Thus you'll be out that cost, if it doesn't solve the problem.
I hope this helps.
Mar 08, 2015 | Office Equipment & Supplies
Aftermarket speakers stoped working
Can a head phone be plug into the unit and if so - can you hear sound over the head phone. Also first look if nothing is stuck in the head phone jack (where it is plugged in as kids tend to stuff small objects into it). If sound can be heard over the head phones the unit is ok. The problem then lies with in the speaker output circuitry. The speaker output wiring has most of the time a inbuilt fuse that protects the circuitry when the speaker wires are shorted out when power (volume) is on. The unit has to be opened to replace it by a knowledgeable person.
Nov 28, 2017 | 2003 Ford Explorer
Wont power on
If you take the face off of the head unit, you will see a reset button. Using a pen, press the button to reset the unit. The first time that you power the unit up, the volume will be at level 12. If this does not work, there is a fuse that is on the power cable of the unit. To get to this, you will need to remove the unit from the dash. You will also want to check the fuse panel in your vehicle to ensure that the fuse which operates the radio is in working condition.
Mar 08, 2011 | Alpine CDA-7897 CD Player
Canon mx330 printer error 5200
Try this: Press the resume button (or cancel).
If not, unplug the unit and plug it back in.
Or, try this: Open the lid so the printer moves the head to the center position and unplug the power cord. Remove the ink and head. Plug the machine back in and let it go through it's startup routine. When it's done, open the lid and reinstall the head/ink cartridges.
If this does not work, you may have a bad printhead. Printheads for Canons cost anywhere from $50 to over $100 depending on where you get them and what model the printer is.
WARNING If, during your testing, the machine suddenly dies completely (no power at all) do not purchase a new print head. Some Canon models have a bad type of failure where the printhead goes bad and shorts, which draws too much current from the main board causing the main board to blow. If you replace the printhead in a machine with a bad main board caused by this failure you will just blow the new printhead. Remember this only applies if your machine suddenly dies completely (no power at all).
Good luck.
Sep 24, 2010 | Office Equipment & Supplies
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
Lost power
You may have blown the fuse in the back of the unit. Take the radio out and check the fuse in the back if that is not the problem the reset button should be back there if it has one.
May 01, 2009 | Car Audio & Video
Apr 04, 2009 | Hitachi RAS-09UH Air Conditioner
I stop getting power or sound to my sub
Double check your fuses. It sounds like you blew a fuse. Check the fuse for the radio aswell as the inline fuse for you amp. On some amplifiers there is a circuit breaker reset button. Check to see if your amp is equiped for that. I did find this quote for reset out of the owners manual.
Remote Turn-on
Automatically turns amplifier on when connected to the head unit's remote output. The
amplifier will turn on and off with the head unit to save current consumption. This control
also operates the reset circuit for the amplifier's protection. It must be connected with
the head unit in order to reset protection circuits.
Mar 28, 2009 | Bazooka BA1500 Car Amp
CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Jun 05, 2008 | Sony CDX-S2000 CD Player
Printer problem
E24 Purge unit error
Reset procedure:
Service mode operation procedures :
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Reset except for the followings:
- USB serial number
- Destination setting
- Waste ink counter
May 11, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Heating & Cooling Logo
Top APC Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an APC Heating and Cooling Expert? Answer questions, earn points and help others
