Question about Cuisinart CBK-200 Bread Maker
The ingredients aren't mixing. I have to take the dough out and
Knead it myself at the same time that I remove the paddle (after 3 sets of 6 beeps). I haven't tried letting it go without manually kneading it, just assuming that the paddles aren't doing the job. There is a lot of flour that hasn't even been mixed in. The machine is brand new. Have only used it twice, once with a box recipe (9 grain) and once from the recipe book that came with the machine (honey whole wheat). The bread isn't really rising very high too.
  • 3 more comments
  • Anonymous Feb 08, 2009
    I have the same problem. My machine is 2 years old, gets used 1-2x/week. It worked great till about 2 weeks ago, then it seemed like the pan shaft froze. The rotor will spin around when the machine empty, but not when the pan is there, with or without ingredients. I thought my pan had gotten too beat up and leaked around the shaft (it was hard to turn the shaft by hand even with pan empty and out of the machine), so I got a new pan, but still same problem. Barely mixes ingredients, no kneading at all. I can look and see the paddle not spinning unless I lift the dough off it with a spoon, even though you can hear the motor working. It seems as if some sort of clutch or gear that is supposed to protect the motor from burning out is slipping, and it won't turn any of the time.
    Same issues as the other two posts, worked great for 2 years and now now mixing the ingredients.
  • kijani Feb 21, 2009
    Sometimes the machine won't mix all the ingredients. I get a lump of dough in the middle and flour sitting around the outside of it. I watch it mixing hoping it will somehow mix all the flour in, but I inevitably have to open it up and knead it myself.
  • jen7570 Apr 02, 2009
    I got my cuisinart breadmaker in Febuary of this year '09 as a Valentines gift. Used it 6 times. It now does not mix the ingredients into a dough ball, paddle barely moves. I've checked everything... What the heck happened? I'm mad.
  • sondra ilnicki
    sondra ilnicki May 02, 2015
    This happened to mine. The 'arm' at the bottom was stuck and wasn't turning. Make sure that the arm is freely turning.
    Master:
  • 985 Answers
Why are yo removing the paddle? Is it to prevent a hole in the bread? It's unavoidable unless you use the dough setting only.
Posted on May 02, 2015
  • 8,596 Answers
My experience with the machine is that it kneads perfectly, but you have to use ACTIVE DRY YEAST instead of another kind of yeast, and you have to throw the ingredients into the pan in order - do not mix the ingredients at all - just pour them in, and let the machine do the mixing. Except for substituting between BREAD FLOUR and WHOLE WHEAT FLOUR, do not substitute any other ingredients. This one is very picky about the type of ingredients that you use - not for the innovator :-)
-Tha Mp3 Doctor
Posted on Feb 07, 2009
My bread maker paddle is turning correctly, but it is not mixing the ingredients. We put liquids in first. The first time we used it, it was perfect?
You may have too dry or too watery a batter. Check your ingredient mix for accurate measurements.
Recheck the unit without ingredients in place to be absolutely sure you have the paddle seated correctly. Although most are designed to make it very hard to put the paddle on incorrectly, old dough or batter may harden in place and keep the paddle form fully seating correctly.
Mar 01, 2015 | Regal Ware Kitchen Appliances - Others
Is there anything I can do?
I don't know about your specific model, but in most bread makers there is a removable paddle that goes in the bottom of the bread pan after you put that in the machine. The paddle usually has a flattened side on the hole which slides on to the post sticking up from the bottom of the machine. If you look at the post straight down from above it should be D shaped. The usual procedure is to put the pan in the machine, install the paddle, and then add your ingredients. Assuming you are doing this and it is still not working, trying running it through a mix only cycle (like for pizza dough) with the machine empty to see if the paddle is engaging and spinning properly. If it is not, contact the manufacturer for assistance.
Aug 08, 2014 | West Bend 41053 Bread & Dough Maker
Kneading Paddle
All bread machines have a final "punch down" of the dough that lasts a few seconds before the final rise stage. When "punch down" is over that is when you can remove the dough ball, remove the paddle, set it aside and place the dough ball back in the pan. It usually helps to have your hands dusted with a little bit of flour.
Apr 21, 2013 | Morphy Richards Kitchen Appliances -...
My breadmaker is on the dough setting and will not beep to let me know when to add ingredients to the dough
If there is no beep just look at your manuals cycle times and verify how long the 2nd knead takes. Then set another timer such as an alarm clock or oven timer etc. to alert you with a beep that coincides with 5 minutes BEFORE then end of the 2nd knead. Add your fruit, nuts etc. then.
Mar 06, 2011 | Black & Decker B2000 Bread Maker
When i put the ingredients as directed, i selected the program then put the delay on. when i woke up expecting fresh bread, i had a hard 3 inch brick with flour and yeast sitting on top of it. was i...
No, Everything should be done automatically. It seems that the machine did not knead the dough. Two things may have caused this. 1) The paddle is frozen and wont turn. Take the pan out of the machine and see if you can rotate the paddle by hand. If yes...that's cool, if no then the sealed bearing that the paddle rotates on is jammed or broken. Try filling the pan with warm water and let it soak. If after a few times it's still frozen, then the bearing is broken and bread pan needs to be replaced. 2) Belt fell off or is snapped. Keep the pan out of the machine and go to a kneading cycle. Look through the window on the lid and see if the motor shaft is turning. If no... the belt fell off or snapped, or the motor is broken. Good luck..Hank
Dec 03, 2009 | Oster 5836 ExpressBake Bread Maker
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
What is a kneading paddle in tr441breadman
It mixes the dough. All you do is put the ingredients into the bread maker, turn it on and wait. It will do all the work for you.
Jan 03, 2009 | Breadman TR444 Bread Maker
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Addidng ingredents
Sorry, I don't know too much about breadmakers, but generally speaking, you add ingredients that you want to remain solid later into the mixture. If you add them before the dough is dough-y, then they'll get crushed.
May 27, 2008 | Sunbeam 5891 Bread Maker
Cuisinart CBK-200 Bread Maker Logo
795 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
