Question about Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher
Can I get a different front door for my dishwasher?
I have a Bosch model SHE44C06UC/22, black and I would like to swap the front door, or even just the skin of the door for the stainless silver one. There is a stainless model in the same line, how do I get on of those doors? I cannot seem to find them.
Thank you for your time and assistance
-KP
  • kevinmich133 Feb 07, 2009
    Thank you for your time and effort. The pics of the door kits you have found are for a model SHV series. My washer is the SHE 44C06UC/22. I spoke with an appliance guy locally and he stated that it isn't possible due to the stainless fronts being 1/4" thicker? He seemed confident, but I'm gonna keep looking
    Thank you again,
    Sniper:
  • 86 Answers
From what I could gather, it appears that there may be a door panel kit available for your dishwasher. The kit appears to have the panel kit and the curved handle included. Some links for visual reference:
SGZ1005UC Stainless w/tubular Towel Bar Handle
SGZ1006UC Stanless w/curved Handle
Posted on Feb 07, 2009
Bosch SHE44C06UC/22 won't fill with water even though you hear water running somewhere.
Check to make sure there is no residual water underneath the unit, they have a flood sensor and if it is picking up water in the motor area it won;t run.
Jan 24, 2014 | Dishwashers
I have an Ariston LI 670 B-S-W. first, I was told this was a Bosch product, and second, I was told I could swap out a custom panel on the front, or purchase a stainless steel door to swap out with the...
True and True - compare the pics of the interiors on the shopping websitses, so see which Bosch model matches (baskets/shelves may be different) but why not keep it as is? Any work to change it could go wrong. Leave working kit alone.
Dec 15, 2013 | Hotpoint-Ariston LI 670 Builtin Dishwasher
The dishwasher is not waiting for the door to close before starting up and it just sounds as if it is draining then nothing happens
Sounds like you need a new "limit switch". If you can't find one here is a very good supplier,they carry all parts for all makes and models. www.apwagner.com/index.php?main_page=page&id..
Mar 17, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
How do you run the diagnostic on a bosch dishwasher model # SHE44C06Uc/22. it counts down to one on the timer and runs forever. can't find it model # diagnostics anywhere. thanks
Resoldering the relay, regardless of how proficient one is at soldering, will not be a long term solution. The melted/burned solder joint is a secondary result of the initial failure, which is the relay itself. There is a solution that is more permanent and less costly than replacing the control with a new one.
Do a search for Bosch 266746 control and you will locate someone who has studied the problem and found a safe, long term solution.
Nov 16, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Have BOSCH diswasher model SHE44C06UC/22 and it continues to cycle but never drys
That could either be a problem with the control module or the heating element...my first guess would be the heating element... as it is looking to sense it working and does not...
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 29, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My Bosch dishwasher won't shut off. The timer says "1" forever and when you open it there is about an inch of SOAPY water still there.If you press start it goes to "13" and again counts down to "1" and...
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Feb 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Not Sanitizing or heating and draining properly
bosch dishwashers run the cycle through the heating element, you may get a 2H displayed. when you wee that it means the heating element is bad, or the board is bad, i will tell you in my 15 years of repair its almost always the board,. if you know someone who is solder literate, the you can remove the board and resolder the connection. you need to remove the screws on the inside top of the door to remove the display panel, after doing so you will see the control board(fisrt turn off the electrical) then remove the wiring harnesses from the control board, the harneses only go in a certain slot so they will be easy to remember where to put back into.open the case of the board, look on the back and you will see where the bad solder joint id...clean, resolder, reinstall......good luck
Dec 27, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Installing a bosch dishwasher SHE44C06UC
just clip it to the side.  I had the same questions after ours was installed wrong
Jul 31, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Front panel
Did you knock out the plug on the disposal before you hooked up the drain hose ?
Aug 19, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher Logo
368 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
