Question about HP PSC 2355v All-In-One InkJet Printer
No power electricity went out - after it came back on printer wont turn on. any fuses anywhere?
  • markes110294 Mar 27, 2009
    the display open HPcan not be initialised ."on button" no green light
  • HP Master
  • 2,404 Answers
No fuses that I know of. Just for the heck of it, hook up the printer to a known good outlet just to be sure its the printer and if still no luck then the printer is bad.
Posted on Feb 07, 2009
The power went off and wen it came back on the tv wont turn back on
If your power outage wad caused by a surge your tv may have died. Check fusebox for tripped circuit breaker also check tv wall plug fuse in case that has blown. It might be that the tv internal fuse has blown, you should disconnect the tvv from the electricity supply if you intend opening the rear of the set to check this.
If they are all okay the set probably needs the services of a trained technician
Good Luck
Jun 08, 2015 | Televison & Video
Epson rx585 wont power back up
open the cartridge campartment and check for any insects or dust clean and try to restart
Apr 03, 2014 | Canon MP560 All-In-One InkJet Printer
Turn the key, nothing happens, new battery
check voltage at main fuse box (what car)? and those fuses.
to fix electrical , "nothing" means , bad head lights.
so that very simple system is the most easiest to diagnose.
voltage at the head light fuse, (no) then move back to the engine bay
fuse box for power on all fuses there (large fuses)
at one point you get 12v (HL are hot all the time)
between the last bad point and the good 12v point is the section that is open circuited.
easy huh?
Feb 10, 2013 | Suzuki Cars & Trucks
No electrical power anywhere
In the engine bay there is a fuse box with some large fuses in it, one of these will be blown.
Mar 13, 2012 | 1990 Chevrolet Lumina APV
I have a 82 yamaha xj650 maxim and i cleaned out the carbs and went to start it up when done and it turned over and tried to start but then everything went dead. i turned key no lights of any kind anywhere...
Check for a fusible link near the battery on the positive side. Also check for a good ground to the frame and that the connections are shiny and bright.
--W/D--
Feb 18, 2011 | 1981 Yamaha XJ 650
I have a 1995 ford mustang v6 3.8 liter automatic, situation- pulled up to a store and got something to drink. went back to the car turn the key over and heard a click and lost all electrical power, the...
check your fuses. I expect its one of you main uses located under he hood. You also have another fuse box under the dash in the drivers side footwell. Check all the fuses and if any are broken and replace if necessary. Further electrical problems will likely need to be diagnosed by a shop.
cheers
May 20, 2010 | 1996 Ford Mustang
1992 cadillac sedan de ville no electrical power anywhere in car
Check power connection by fuse panels under hood just below the center of windshield
Mar 12, 2009 | 1992 Cadillac DeVille
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
HP PSC 2355v All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
