Question about Brother MFC-9440CN Laser Printer
MFC-9440 CN--Lines in my auto feed scanned/faxed copies
My 5-month old 3-in-1 makes perfect copies and scans when I do a single page on the glass. However, whenever I use the auto feeder (photocopies, faxes or scans), I get 4 or 5 lines, from the top to the bottom of the page, about 1.5" from the left margin. This problem has persisted from when I bought the printer, through changing out all of the toner cart cartridges (including the cleaning that you do by moving that plastic tab back and forth several times, then returning it to its original position).
  • dhigham Feb 07, 2009
    That was WAY to easy. Worked like a charm. Thanks!
    Problem Solver:
  • 5 Answers
Clean the thin strip of glass located under the document feeder with something non abrasive
Posted on Feb 06, 2009
When I receive a fax, it prints out perfectly. When I make a copy or scan to fax/email, the page has multiple black lines running down the length of the page. I have recently replaced the drum and the...
As the fax receives and prints incoming faxes ok then the print engine is working ok. the fact that the problem arises when copying or scanning indicates the problem is with the scanner or software that controls the scanner.
First clean both scanner glasses and the white area (white reference) under the doc feeder. When you are happy all is clean, follow the following instructions:
Press menu, * 2864 within 3 seconds. the display will show "Maintenance"
now press 55. The scanner will initialise and go back to "Maintenance"
now press 99 and the machine will go back to the default screen showing date and time.
Now do a copy. if you still have the lines or its all black then you will need a new contact image sensor. If all is well then that was a good cheap repair.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
May 20, 2010 | Brother MFC-7440N Laser Printer
AUTOMATIC FEEDER LEAVING LINE ON SCANNED PRINT-OUT
clean the thin DF glass strip on the left side with a damp cloth
Mar 15, 2010 | Brother MFC 6490CW InkJet Printer
I get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 12, 2010 | Brother MFC-9440CN Laser Printer
Vertical lines in copies and scanning
You need to clean small exposure glass located on the left of the main exposure glass.If this doesn't help,it can be a dust under the glass or on the mirrors that causing lines.
Oct 06, 2009 | Brother MFC 6490CW InkJet Printer
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-9440CN Laser Printer Logo
409 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
