Question about Samsung SCX 4521F All-In-One Laser Printer
How do i enter the distinctive ring sound for the fax?
I have one phone line with 2 rings, one normal ring for when people dial my phone number to talk to me and another ring (1long -2 short sounds) when people dial another number to send me faxes. i programmed the number for the fax line in the machine but it still takes both lines as a fax leaving the people who dial the first number to talk to me on a fax sound. When I try to program the machine it says(WAITING RING) HOW DO I PROGRAM THE RING?
P.S. I do not have a manual with my machine.
    Problem Solver:
  • 5 Answers
Click on menu/setup button
then advanced fax setup-ok
answer ring pattern-ok
chose from single, double, double and triple, none-ok
Posted on Feb 06, 2009
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
We cannot receive or send a fax. If I dial our fax number it rings as a normal phone and not the sound that a fax number makes. The machine is only a few months old.
Not sure how a fax machine is supposed to sound when it rings, before the fax answers it will sound exactly the same on the phone as dialing a regular phone number. If you are using distinct ring tone service where the fax line is supposed to double ring and it is not then it is possible that your phone provider has problems. Are you able to make a regular voice call on the phone line that the fax is supposed to use? If no, then it is definetly the line not the machine.
Apr 18, 2011 | Samsung CLX-3160 All-In-One Laser Printer
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Our IntelliFax 4750e will not receive faxes. The line has a dial tone, and rings when called. It is set to "fax" and not "fax/tele." Suggestions?
There are a few possibilities. 1) The phone cord coming from the wall is plugged into the phone port on the fax instead of the Line port. It should be on the line port.
2) The fax have been set for distinctive ring. This causes the fax to ignore the normal incoming ring tone and is instead waiting for the distinctive ring from the phone co.
3) The modem in the fax has gone bad. If you have had any power failures or electrical storms/problems this is a possible cause.
Some models will also not answer if the machine is out of toner or paper.
Oct 21, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Every time when the phone rings and I answer it the fax kicks in with that really annoying sound. I have to shut down the fax and plug it back in after I am done my call. what is the normal setting for...
The fax is on what you call a Distinctive Ring tone. You need to go in to the settings on the fax machine, and look for Ring type, or Distinctive Ring, And set it to 2 or 3, Dependent on how the phone rings on the fax number.
Nov 25, 2008 | Samsung Office Equipment & Supplies
Fax phone hookup
Use an identa call box. You set the distinctive ring pattern (1-2-3) and the box will route the call through depending on what number it is. I have two numbers on one line. I have a tee adapter on the phone plug with two phone cables coming out. Each phone cable one plugs into a small distinctive ring box. I set one box switch to 1, and the second box to 2. If the first phone# rings box 1 allows the signal through to the phone. If the fax line rings the phone won't ring, but the second box will pass connection to fax and vise versa.
I brought mine from Bell Canada phone store. It is called a identa-call box, or distinctive ring switch. Best way to go !
Mar 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
How do I change ringing to all handsets at the same time
SET ring to standard and not musical or distinctive ring. SINCE I am in India WHAT kind of line you are using isnot known.thereis setting on FAX to detect fax tone. Switch phone Fax switch to AUTO.
Mar 18, 2008 | Uniden TRU8885-2 Cordless Phone
Phone line and fax line
If you actually have a 2 line setup with 2 #'s each with it's own separate line, it's wired backwards. Otherwise (distinctive ring, etc) the machine has to be capable of and set-up to recognize which ring pattern is a fax call.
Also, you have to enable auto-answer on the fax machine.
Feb 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
Aug 29, 2007 | HP 1040 Plain Paper Inkjet Fax
Samsung SCX 4521F All-In-One Laser Printer Logo
175 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
