Question about Dell Inspiron 1501 Notebook
Can't get past black screen and mouse
Have tried reinstalling vista, but inspiron 1525 doesn't seem to pick up the cd after initially sounding promising. I am stuck with the mouse, fully moveable against a black backdrop; the only screen so come up after 'start windows normally' screen.
Any ideas?
  • rainejose Feb 12, 2009
    Thank you for replying; it has been identified as a Vista software problem, and I have got an IT expert to reinstall it, I hope!
  • itzmetoo May 11, 2010
    Hi
    i think i can help on this but i need more info from you i want to know what happen from the begining itself and what r all the steps u tried.
  • 56 Answers
Power off your computer, then power on hitting F12, del or whichever key it states to go into setup. From the setup menu, select change boot order or boot menu. Set the CD ROM to the first boot device. Save changes. Restart. Your computer should boot to cd starting the installation.
Posted on Apr 16, 2009
My Dell Inspiron 1525 laptop will not boot, I have tried reloading but all that I get is just a dark screen, and a message that says press any key to boot from CD....
Seems that there is a cd in the cd drive.take it out and this will be fixed. if not then you will have to reinstall everything data will be lost.you can try pc restore. power on the system and press ctrl and F11 .if this doesn't work then you will have to use the windows cd to reinstall everything.
Oct 25, 2010 | Dell Inspiron 1525 Notebook
DELL INSPIRON 1525 NOTEBOOK : HELP !! my dell inspiron 1525 notebook will not start windows. the battery is fully charged and when i press the power button a black screen comes up and it says : "windows...
This sounds like the dreaded Windows Vista Black Screen of Death (KSOD). you might have a bad hard drive, but even more likely some software or a driver is causing a problem and caused Vista to get stuck. The repair will not work. You might be able to run a complete repair from the Windows Vista CD, if you have one. If you are not too experienced, take it to a reputable computer service center. If you are at all technical and have time, google your problem and you will see thousands of similar users with same problems.
This is one reason Microsoft released Windows 7 so soon.
Feb 16, 2010 | Dell Inspiron 1525 Notebook
I was having problems with reinstalling vista
use recovery disk to restore vista. if ur pc had data take ur pc to experts.
Feb 07, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 network adapter stopped working after vista reinstallment
do one thing right click on my computer and go to properties , then go to Hardware Tab , under Hardware tab click device manager then u will be able to trace ur 1525 adapter there ,if it is not working properly then a question mark will be indicated before it...
ok do one thing right click on that and uninstall it or remove it then take ur driver cd and install it again with ur cd .... if it doesnot work then go to internet and download latest driver for the adapter for vista ...that;s it
Feb 02, 2010 | Dell Inspiron 1525 Laptop Jet Black
My dell inspiron 1525 webcam wont work with yahoo messenger
This is happening because the Dell webcam central is accessing the webcam at the same time as yahoo messenger. Click on start and click on Run(XP), Type MSCONFIG in start search (Vista) and you'll get the system configuration utility. Open it and go to the startup tab. Uncheck anything related to Dell webcam. Click on Apply and OK and restart the computer. If yahoo messenger shows a black screen uninstall Yahoo messenger and reinstall with the more recent version.
Aug 09, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell insiron 1525
My father had a similar problem with the HP he has. Basically, what has happened is the actual script that controls where the boot sector is located is corrupt.
Boot with your first recovery disk and try to fix the issue. If this doesn't work, then you'll have to reinstall.
Jul 25, 2009 | Dell Inspiron 1420 Notebook
Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Apr 20, 2009 | Dell Inspiron 1525 Notebook
Black Screen
try booting from a cd like the reinstall cd for windows that came with the computer. when starting hit F12 to show 1 time boot menu; select cd drive; hit any key when asked to boot from cd. This will tell you if its a software or hard drive problem.
Feb 18, 2009 | Dell Inspiron 1525 Notebook
Black screen with mouse only
there are several things which might resolve your problem.
attempt to get into safe mode (with f 8 at boot), and check device manager for problem devices.
insert the vista disk and boot, and attempt to "repair" windows, the boot sector particularly. there is usually a "repair" utility on windows disks which allows you to fix problems without completely reinstalling windows.
your computer may be infected by a virus. if you can get into safe mode, try a virus scanner called "avast" if that doesnt work, try "malwarebytes" or "combofix". these can be found by doing a quick google searc, just make sure you download them from reputable sites. you may have to use a seperate comoputer to download the programs.
if you cannot get into safemode, try the same anti-virus software suites, from a different computer, with your hard drive installed in that system as a "secondary" drive. if this is a laptop hard drive, laptop to desktop hard drive adapters can be purchased for around $20.
Dec 17, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
332 people viewed this question
Alun Cox
