Question about Dell 922 All-In-One InkJet Printer
Alignment problem printer wont align has alignment problems
  • romans_1 Feb 06, 2009
    uninstalled and installed and still has alignment problem
    President:
  • 2,976 Answers
Take out the ink cartridges & reinstall them. Also, make sure your paper tray isn't allowing too much slop around for the paper.
Posted on Feb 06, 2009
  • Dell Master
  • 1,800 Answers
Uninstgall and instgall drivers and strat the alignement utility.
plz rate this post.
THE ALIGNMENT PAGE WONT SCAN
If the data is blurry, then the alignment would not be successful.
Please check if the ink volume in the cartridges is > 30%.
Sep 23, 2014 | HP PhotoSmart C4480 All-in-One Printer ...
Hp 8500 printer stuck in continuous cleaning and alignment loop after replacing cartridge
Printer wont do the alignment process if we replaced the cartridges, might be removed/re inserted the printer heads, then ply it process the alignment, if the print head nozzles are clogged, alignment process wont completes..
>Remove the print heads clean the nozzles with tissue paper gently at nozzles.
>borwse this link & see how to clean the print head,link:http://www.youtube.com/watch?v=ZAwYIbjswV0&feature=related
>Install the printer heads do the alignment..
> if not completed check which printer head clogged, replace the print head.
Oct 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My printer wnt work i boght new ink but it wont print
Hi
whenever you put new ink cartridges,your printer prints an alignment sheet
if your printer isn't printing,
one of the concern could be that it didn't print the alignment,uninstall the cartridges and put them back again.
also try printing an alignment sheet using the printer driver located in the control panel,printers and faxes
once you go into the properties and click on the device settings and click on service this device you will get option to print alignment sheet
this should work
Jul 17, 2009 | Dell 926 All-In-One InkJet Printer
I have the hp d1400 series...it wont print and its telling me i have an alignment problem..it all stemed from me changing my printer cardridge
Align the new print cartridge
  1. On the Windows taskbar, click Start .
  2. Click Programs or All Programs , click HP , and then click HP Solution Center .
  3. In HP Solution Center , click Settings , click Print Settings , and then click Printer Toolbox . The Printer Toolbox opens.
  4. Click Align the Print Cartridges .
  5. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and calibrates the printer.
  6. Recycle or discard the test page.
Mar 11, 2009 | Lexmark Office Equipment & Supplies
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
Printer wont align
Can you complete the alignment through the maintenance tab on the driver via your computer?
Jul 26, 2007 | HP PSC 2410 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
79 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
