Question about HP Photosmart 2575 All-In-One InkJet Printer
Colours are mixed up/non existent on printout.
Recently i played around with some applications that i THOUGHT i didn't use, to free up my cpu memory space. I must have unticked something to do with the printer driver, as now when i print off images (a colourwheel, might i add..), all i get is yellow, white and a bit of pink. That's it. I don't think i've run out of ink, as there is a small hint of blue at the top of the print off.
  • HP Master
  • 2,404 Answers
Uninstall the printer drivers and then reinstall them for the printer and then see if it corrects the problem if not then I think maybe you didn't do anything and maybe its just that the color cartridge is getting empty? Take out the cartridge and see if it feels light, if it does then your color cartridge is getting empty and will need to be refilled or replaced. Also could be the ink is drying up in the color cartridge, that can happen alot to.
Posted on Feb 07, 2009
What is the cause of characterized printout. When I printout a test page, it just prints all sort of digits and numerals in no chronological order. What is the cause, is it the motherboard??
A print test page does just that the printer will print every character that is in its memory, together with lines and if it has colours will also use the different colours
Oct 06, 2015 | Office Equipment & Supplies
Acer aspire, windows 7, frequently hangs and crashes. Perfmon shows virtually no free memory (<100 Mb) with kernel non-paged memory at 75% of total memory (4096 Mb) available. CPU is idle. Any idea
Something consumes too much memory.
1) If you are running "memory demanding" applications, this might be the case
2) If you have caught some malware, that might be the case as well
3) You might have to check how much virtual memory you have allocated to your system and in case it is low, try to increase it!
First of all, check if there is/are aplications (and what they are..) which consume memory...
Jan 26, 2014 | Acer Aspire Computers & Internet
Installed corsair h60 and now the computer switces on but the screen is blank
when installing ram always keep the largest module closest thr CPU central processing unit
it sounds like a compatability issue
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
you can check the compatability using this memory advisor
NON-ECC/Non-parity - Most desktop and laptop computers take NON-ECC or Non-parity memory.
ECC/Parity - ECC or parity modules look for errors in data and are most often found in servers and other mission-critical applications used by large networks and businesses.
Unbuffered - Most PCs and workstations use unbuffered memory which is faster than registered memory.
Registered/Buffered - Registered or buffered modules delay all information transferred to the module by one clock cycle. This type of memory is primarily used in servers.
Fully buffered - Designed for next-generation servers, features an advanced memory buffer.
CL - CAS (column address strobe) latency, which is the number of clock cycles it takes before data starts to flow after a command is received. Lower CL is faster. Modules with different CL can be mixed on a system, but the system will only run at the highest (slowest) CL.
Component configuration - (For example: 64Meg x 64) Indicates the size of the memory chip components on the module.
Voltage - For example 2.6V. Indicates the power used by the module. The lower the better. Check the glossary and FAQs for more detailed definitions.
hope this helps you
Sep 24, 2011 | EliteGroup A790GXM-A Motherboard
My computer will not play vidios it just plays alittleand then stops and then in about 5 seconds it starts again
sounds like it's "too hard" for your computer to play the videos. Are non-HD videos work fine?
To begin with, uninstall any codecs installed on your computer. Restart, then install K-Lite Codec Pack.
If the problem persists, follow these steps, each one at a time:
* Check the CPU temperature (easiest way - in the BIOS). If it's around 50*C or above - you need to clean/replace the heatsink/CPU fan.
* Check for faulty memory modules. you can use this tool for the job: MemTest86+
If a faulty module's found - replace it. In any case, a total of at least 1GB in recommended these days.
* Check for defective graphic adapter. Use this software: 3DMark
Good luck
Mar 14, 2010 | Computers & Internet
I cant play my gamesaves qhen i want to play gta 3 or gta vc
Does the save location exist?
Make sure that these two files exist on your computer:
for GTA III
My Documents\GTA3 User Files
for GTA: VC
My Documents\GTA Vice City User Files
Have you tried downloading save files off the internet to check if it's the applications ability to read?
http://www.gtasavegames.com/savegames/gta_iii
http://www.gtasavegames.com/savegames/Vice_City
Also, check if your antivirus is blocking the application from reading the memory.
Aug 07, 2009 | Video Game Consoles & Games
Saturn '99 SL2 erratic tickover on idle
Idle problem most likey a Coolant Temp sensor & connector.Cam covers very common to leak around the sides & down into the spark plug holes.Also all saturn s-series 1.9 engine consume oil.Most 1qt. per 1500 miles some more some less.Service Engine Lamp has nothing to do with regular maintenance.It's a malfunction indicator lamp.If it's on there is Trouble codes stored in the ECM.Auto zone free scan with printout.Hope that helps
May 12, 2009 | 1993 Saturn SL2
Divide Overflow Error msg
well, in DOS the game Wizardy - Bane , still shows up the divide error msg
how ever, i decided to try to run the game in windows 3.11
and it worked!
i am happy.
so, this really wasnt a true fix, but more of a work around
Dec 25, 2008 | Microsoft Windows 98 for PC
Colours not printing correctly
please check the charging roller of your new cartridge
Sep 07, 2007 | Epson AcuLaser C900 Printer
HP laptop suddenly shuts down
clean ur cpu fan, its ventilaion is not occouring properly
Dec 11, 2006 | X-10 NU SBW242B/SBW242C Slim DVD/CD-RW...
HP Photosmart 2575 All-In-One InkJet Printer Logo
37 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
