Question about Panasonic DMR-HS2 DVD Recorder
RAM Disk won't eject
The problem happened after viewing the RAM disk when I accidentally hit the record button on the remote by mistake -- sending the recorder in recording on the available space on the RAM disk. After hitting the stop button a couple ot times NOTHING happened. The HS2 continued recording until I turned off the power from the player itself.
Now the recorder is "locked" into a "continuous loop" of recovery when powered up. After a few minutes, the player's front panel says "bye" and the DVD recorder turns off.
Panasonic says I should send the unit in for repair. However, I am thinking opening the recorder and seeing if I can remove the DVD-RAM disc myself.
Any help would be nice, so thanks in advance.
  • rone10258 Feb 06, 2009
    Tkx localwonder for the prompt reply.
    Panasonic gave me the "ch up and stop" button combo to try after unplugging and replugging the power cord for about 15 seconds. As you probably know -- this doesn't work in this situation.
    I've already tried unplugging the recorder overnight, thinking (and hoping) that it would "reset" itself. But it did NOT!
You can remove the DVD disk manually. Take off the main case after of course removing the mains lead! The DVD drive cover (black plastic) is held by four small brass screws. Remove these. Carefully lift up the ribbon cable that crosses over the DVD drive but don't disconnect it. Theres plenty of spare cable to allow you to remove the cover. From the back of the drive lift up the cover and pull it back and under the ribbon cable. Finally, lift out the old DVD and discard it if you don't want any more problems. Be careful when re-assembling to ensure that you get the cover to go under the ribbon cable and to line up with the mechanical parts of the drive. (There is a wavy slot in the cover for the mechanism to sit in)Also make sure that the earth tag fits back under the proper fixing screw. The Panasonic will restart without returning to the recovery mode once the disk is removed in this way.
Good luck
John
Posted on Dec 27, 2009
  • 6,784 Answers
Unfortunately, this unit is on system lock down due to massive main board failure. its kinda like a system protect mode. this can only be repaired by the manufacture or maybe an in house tech with knowledge of the board outline. i don't think this unit has an escape code for retrieving the dvd. hope that helps ya and thanks for using fixya:)
Posted on Feb 06, 2009
  • Michael Masters
    Michael Masters Feb 06, 2009
    one more thing, try unplugging the unit for about 12 mins. this may reset the board.
  • Michael Masters
    i see, this protect mode is very crude. i would send it in for a rebuild or, just cut the loss and buy another.
How to remove a dvd when no power to tv?
If not already done so, check the instruction manual (on-line if you don't have a copy) to see if there is anything about this in the troubleshooting guide - it may have a key combination on the remote or similar to force eject the disk. Failing this, if you can open the outer flap of the disk drawer without forcing it, you may find a small reset hole which can eject the disk manually by using something like a straightened paper clip to put into the hole and press the recessed button that is accessible via the hole. It can be a little difficult to find as depending on the design of the TV, it can be obscured behind the plastic of the TV body. Don't be tempted to force the disk drawer out as this can knacker the mechanism completely. BTW, if the disk is not a pre-recorded disk, (recorded yourself), this can cause an error like this - powering everything off and then pressing and holding the eject button as you power up may result in an eject. Hope it helps!
Feb 24, 2015 | Naxa Ntd-1952 19" Widescreen Hd Led 1080p...
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
DVD+R stuck in logik ldvr808 recorder
Pull out the power cable and leave for a few minutes then plug it back in. Now before the DVD player tries to play the disk press EJECT or OPEN/CLOSE button continously until it releases the disk.
Jul 10, 2009 | Televison & Video
When i try to open my disk tray it says locked
I had same problem with JVC player. Found out from manual that there is child lock- activated by pressing stop + eject when unit in stand-by mode. (which I must have done accidentally) Unlocked by repeating action - in stand by mode.
May 24, 2008 | Televison & Video
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Endless loop
Mine did this (on a Ram disk) but I was able to push eject before the dvd tried to read the disk. I had unplugged it overnight, then once plugged back in immediately pushed eject. Once the disk was out it stopped going into recovery mode.
Hope it helps. Good Luck.
Sep 27, 2007 | Panasonic DMR-E80H DVD Recorder
Reading and bad disk
You can press the eject button on the drive behind the front panel or connect the ribbon cable from the drive to a PC to eject it. More instructions are on my website here: www.drx9000repair.netfirms.com/
Mar 02, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Panasonic DMR-HS2 DVD Recorder Logo
309 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
