Question about GE 25GT240 25" TV
No video input, just audio, brand new TOSHIBA HDTV
I just recently got a TOHSIBA 37 AV50U... Everything seemed perfect for the first few weeks just running cable and HDMI. I went to hook up my DVD player with RCA's (red,white,yellow) and i'm only receiving the sound, no picture. But, when I have the video (yellow) unplugged my TV will say "no signal" and when I plug it in the no signal sign disappears as if it is getting something. I tried this with my PS3, my cable box, as well as another DVD player, same result. I also switched RCA cables out to make sure there was no problem with wiring. I also tried the RCA pluggs on the side of the TV (which is Video 2) and still only sound, no video.
I called tech support and they were no help except ( if ) it is under warranty (1 year) and they told me to call an electronic repair shop. I got the item off online and i'm not sure if warranty is void because it went through another dealer?? Thanks so much for any help!!!!
tvtek
  • 1284 Answers
SOURCE: Can't get my DVD player to work...
Your GE TV most likely doesn't have anything but a antenna input on it? If that the case to connect a DVD player you must purchase a RF modulator to convert the video and audio output of a DVD player to a channel 3 or 4 output. Here is a link for one at Radio Shack.
http://www.radioshack.com/product/index.jsp?productId=2103095&cp=&sr=1&origkw=rf+modulator&kw=rf+modulator&parentPage=search
Posted on Dec 01, 2007
MikeMaierTV
  • 206 Answers
SOURCE: Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Posted on Feb 20, 2008
betz73
  • 298 Answers
SOURCE: Where to connect video plug
go to a department store and get an RF converter they are relatively cheap any more maybe 10 buck or so.. follow the instructions that come with they are real easy to hook up.
Posted on Aug 16, 2008
rlj70
  • 3 Answers
SOURCE: 31GT720 GE Stereo Monitor
I have the same TV. Make sure you have hooked up the red, white, yellow leads from the "out" jacks on the DVD to the same colored "in" jacks on the back of the TV. You also have to make sure your TV is set to Video Mode. I do this with the GE remote that came with the TV. There is a WHO-INPUT button on the left side of the remote, 3rd from the bottom. Toggling this button should switch you between TV and Video mode. Hope this works for you.
Posted on Feb 20, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I cant get my dvd to play using my rf modulator
Plug the DVD video and audio cables in to the RF converter. Connect the cable box output to the antenna input connector on the RF converter. Connect the RF converter output to the TV antenna jack. This way, when the converter is off it will pass the cable box signal through to the TV. (Most RF converters are auto-sensing. When it detects the a/v signals from the DVD player it switches its output on, and switches back to the cable box signal when you turn off the DVD.) Also be sure the RF converter is plugged in to AC power.
If you've done all this and you still have fuzzy pictures on either of the converter's output channels, you have a bad converter. Return it if you can, or replace it.
Posted on Apr 23, 2009
Panasonic tcl 37 problem of no sound. Picture is perfect. just installed to hdtv cable box. control show sound but none are present. ? Connections.
Make sure you have the red & white audio output from the box going to the same input source your using for the video but will say audio in.
Dec 04, 2010 | Panasonic TCL37X2 37 in. TV
XBox Audio Problems
The red, blue and green are ONLY the Video outputs, and connect colour to colour, now, there are Two other connections, again coulor to coulor, usually red & white, that hook up to the Stereo INPUT. So you need BOTH sets to work IE: The Video & Audio. Video: Blue, Red, Green. Audio: Red & White.
Jan 20, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have just got a Toshiba 37AV502R flat screen tv. I want to connect the digital audio output (optical) to my older 5.1 speaker system. The input on the sub woofer is a 15 pin VGA... I can't seem to find a...
Is this sub a Bose. The only reason you would see a VGA type connector on a sub is if it is dedicated to somthing else such as Bose 3-2-1 system. This is not a standard VGA input and can only be connected the the dedicated head unit. I need more info on the sub. Brand and model. Ther should be an analog audio input on the sub. This will be sufficient.
Oct 31, 2009 | Toshiba 37AV502R 37 in. LCD TV
2004 Toshiba 37' LCD HDTV-No video only audio?
This problem is caused by at lease one of three conditions;
1) The inverter board(s) is bad.
2) The power supply for the inverter board is bad.
3) You have bad CCFT(s) (Cold Cathode Florescent Light)
Mar 07, 2009 | Toshiba 37HL67 37 in. LCD HDTV
Panasonic TH-37PD25 plasma has no sound
If all of your connector cables are in good standing and your input/output ports are hooked up correctly, this may be an audio defect developing in the processor board. I can walk you through some steps to confirm this problem.
e-mail me: circuitworld@comcast.net
Feb 12, 2009 | Panasonic TH-37PX25U/P 37 in. HDTV Plasma
No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Feb 06, 2009 | Toshiba 37AV500U 37 in. LCD TV
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
Have an AVR-2807 with a Toshiba DVD and Harmony remote. Havent played a DVD for a while and tonight when I try, I get picture and no sound. If I move the input to CD I get sound but I lose picture. ...
Have you changed the connections recently? If so, maybe something got plugged back in differently.
Otherwise check the AVR-2807's System Setup. There is a menu to associate different video inputs to each of the audio inputs. Probably the input with sound doesn't have the right video input associated with it, though I'm not sure you can associate a video input with the CD input... which tells me maybe the connections got changed?
Apr 05, 2008 | Televison & Video
Video input problems
If its a brand new set and never worked from the get go I bet ya 10 to 1 that theres a plug or clip lose in the set someware. Hope ya got a warrantee as you should have unless you bought if off A corner someware. Call the repair service # thats in the owners manual to get it fixed asap. Good Luck
May 27, 2006 | Toshiba 46HM95 46" HDTV
GE 25GT240 25" TV Logo
260 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
