Question about E-Machines D2046 PC Desktop
Powerbutton connection wires were disconnected from motherboard
Power supply went bad on d2046 emachine,when replacing power supply on d2046 emachine the black&white wires labled power sw leading from the power button came loose from motherboard and not sure where they were plugged into on motherboard.computer wont start and green light doesnt come on.
    Sergeant:
    Champion:
  • 357 Answers
Look in the manual there is a diagram and pin connections for each wire.
Posted on Feb 06, 2009
Wires disconnected from power supply need wiring order
Theres no specific order for power supply wires. Just make sure it is disconnected from a power source and connect the Motherboard and optical drive cables to their respective plugs(plugs are standard for most motherboards).
Feb 27, 2011 | eMachines T3604 PC Desktop
I have a emachines t2984 i press the power button and doesnt turn on i replaced the power supply with different ones and nothing and the light turns on (power button) but the when i press the button the...
Ok, test the power button pins. First disconnect any power source to the computer. Then, find the power pins on your motherboard (the one that your case's power button connects to. Usually two wires, one red and the other black). Grab a jumper a connect it to those two pins, they usually have the letters "pwr" or "power" printed next to them. Then, once you've done this, with the jumper connected, connect the power cord to your power supply. It should turn on by it self. If it does, then the problem is the power button. If it does not do it, then the problem is the motherboard. Good luck.
Jan 22, 2010 | E-Machines eMachines Refurbished EMA...
Will not power up
This is a common problem with Emachine motherboards, the problem is the power supply is a best tech and allows voltage surges to the motherboard which fries it too. If available you usually have to replace both the power supply and motherboard. I do not know what exactly goes bad on the motherboard but I have replaced many emachine power supplies and motherboards. The motherboard kit which used to be available from Emachines included a power supply and no warranty if you didn't change the power supply. They knew they had a problem.
Dec 27, 2009 | E-Machines (308714) Motherboard
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
When i turn the power on the green power supply light goes out and doesnt turn onand the computer wont turn on
Follow these:
  1. Unplug the computer.
  2. Disconnect the power supply from the motherboard and all other accessories.
  3. Replug the power supply.
  4. Connect the green wire (PSON) of the power supply by way of a jumper wire to any black wire (ground).
  5. The power supply should turn on with its fan. If not, it is defective and should be replaced.
  6. Check the ATX12V connector of your motherboard. It is were you removed the 4-wire, 2 yellow and 2 black, connector of the power supply. Check the continuity of the yellow wires to the black ones. It should be open, otherwise it is shorted and your processor is defective and should be replaced.
Aug 19, 2009 | E-Machines Emachine T5026 power supply **...
Emachine won't turn on
With an Emachine it can be the power supply or the motherboard.
My guess it is the capacitors on the motherboard. Check to see if the round cylinders on the motherboard are bulging on the ends, and possibly rusty looking. Esp around the Main CPU/Fan.
They are notorious for bad capacitors.
If the caps look good, it still could be the motherboard, or maybe the power supply. Switcing out the power supply is pretty easy.
Unplug
disconnect all the power connectors
unscrew the 4 screws on the back of the computer
remove and replace the power supply.
Make sure you get a power supply with as much power, or more is much better. 350 watt or higher.
For more on the capacitor plaugue, check here
http://paulrepair.blogspot.com/2009/03/blown-capacitors-it-is-plague.html
Mar 25, 2009 | E-Machines Emachine T5026 power supply **...
I have a Emachines w4682 and the monitor was showing no signal when I turned computer on. I hooked up a different monitor and that one worked so I re connected the original monitor and it worked I then got...
Possible reasons are bad power switch, bad power supply, bad motherboard, bad memory , device card is not seated properly. Suggest replace power cord to see if still no power, also you may want to remove cover and make sure all your memory and device cards are seated corrrectly. If you get a amber light at the power button, bad motherboard is likely cause
Mar 24, 2009 | E-Machines eMachines Desktop PC
Replaced dead power supply computer still dead
hi
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Feb 07, 2009 | E-Machines D2046 PC Desktop
Wont boot
If it is checking the key board and hard disk lights are ON ,then try fixing the memory card(s) frist after taking out one by one. If it still dont work check your hard disk by testing it on some other PC.If it dont work ther also than Disk is crashed.
Jan 09, 2009 | E-Machines Emachine T5026 power supply **...
T5026 won't start up
Unplug the power cord, open the computer and disconnect all the power cables (the cables going from the power supply to motherboard and drives). Then reconnect the power cord and see if the light on the PSU comes on, if so disconnect the power cord and plug in the motherboard connectors and continue connecting components one by one to determine which may be the problem. If no power light with everything disconnected then the PSU needs replaced.
Jan 03, 2009 | E-Machines Emachine T5026 power supply **...
E-Machines D2046 PC Desktop Logo
365 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
