Question about Polar M61 Heart Rate Monitor Watch HRM M61
Watch won't read heart rate
I put on the heart rate monitoring strap and turn the watch to the exercise mode and NOTHING. I keep adjusting the strap, nothing...it is so annoying that now I don't use it. Any suggestions?
  • robinlwolfe Feb 13, 2009
    I have the next up model, the F7 and am having the same problem. I "just" bought it, but want to figure it out to make sure that it isn't human error before I return it. Did you ever figure out how to get it to work?!!?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 59 Answers
It could be the battery on the strap is not good. However just to be sure make sure you are wetting the strap and it is around chest, front should sit right about on the bottom of pectoral or chest, if you are female make sure it is under your sports bra the bra band will be over it. I would start warming up then hit the start button it should work.
Posted on Mar 08, 2009
Tip
Tips For Your Heart Rate Monitor
First, you want to adjust the fit of the chest strap. <br /> <br /> Moistening give a more comfortable fit by reducing friction and will also help create a better connection between your skin and the receiver. It can also increase the lifespan of your belt.<br /> <br /> When properly looked after, your heart rate monitor watch should far outlive the chest strap. More often than not any problems you find with the watch can be traced to the chest strap or the batteryIn terms of conservation, the most important thing you can do is ensure that your watch is no longer monitoring after you return from your run. <br /> <br /> This should be easily achievable through the interface on the watch. Separating the watch from the monitor component by a significant distance will ensure that no unwanted connections continue after use.<br /> <br /> Where possible, make sure to remove the electrical component before rinsing the strap with some running tap water. If the watch and electrical component are particularly dirty, you can use a damp cloth to wipe them down, before putting everything aside to dry. Be sure not to leave the chest strap in the sun as this can cause the material to deform, making it itchy and uncomfortable to wear.
on Jan 08, 2011 | Exercise & Fitness
Tip
Trouble with heart rate monitor reading heart rate.
Can't get a heart rate to show on your heart rate monitor? If there are no other issues with the watch, then most likely what you are experiencing is an issue with the Heart Rate Strap.
It is very common for all brands of heart rate monitors to have issues with measurement.
The #1 reason is poor contact with the strap and your skin. - Make sure the contacts are wet and touching the skin with good contact.
#2 reason - Weak battery, may need to replace.
#3 reason - Sensors on strap have salt build up from sweat - Clean the strap and contacts with soap and water, if deep cleaning is neccessary use a q-tip and some rubbing alcohol.
#4 reason - Strap is too low on the body, raise as high on the chest as possible to just under the breasts. Strap too low will cause a weak signal.
If none of these seem to help, then you should contact an authorized repair center or the customer service for your brand, and see about possible repair or exchange/ return.
on Dec 06, 2010 | Watches
I just received a brand new Garmin FR 60 with HRM monitor strap and ANT USB from Amazon. I followed the directions to use the strap[wet the electrodes, strap it over my chest, with the Garmin logo facing...
navigate using mode button to enter into watch's menu tree for settings/ sport/ run/ heart rate and turn on the heart rate monitor to hopefully detect and scan for the garmin ant+ protocol heart rate strap!
Sep 22, 2011 | Watches
My watch does not show heart rate
I have a problem solving checklist about getting Heart rate readings in my tips and tricks page that may be helpful.
#1) you have to make sure the strap is across your chest and contacting the skin directly
#2) you have to push the button on the front of your watch to turn it on.
After that it should read automatically, there is no trick to your watch.
Jan 04, 2011 | Polar FS1 Unisex Heart Rate Monitor Watch
I need to set the heart rate monitor to on
Press OK until the watch is in exercise mode.
Does this solve your problem?
Jul 03, 2010 | Polar F11 Heart Rate Monitor
My heart rate monitor keeps stopping picking up my heart rate (reading of 00 or --), i have changed the battery in the chest strap, not difference, any ideas?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all POLAR watch manuals. Rate me, please.
Mar 03, 2010 | Polar F11 Heart Rate Monitor
Polar F7 not getting a reading when setting it up
How old is it? It could be the strap battery is not good.
Feb 13, 2009 | Exercise & Fitness
Timex M515 Heartb Rate Monitor in correct readings
I´m experienced the same problem of incorrect readings after a long time without use. I cleaned the rubber parts of the chest strap with soap and water, than I use some silicone grease or other silicon liquid to keep the rubber hydrated. Make a careful cleaning in the contact area between the rubber and the plastic parts, the fissure in these area use to be full of "sweat dust".
Jan 03, 2009 | Timex Digital 30 Lap Heart Rate Monitor...
Polar M61 Heart Rate Monitor Watch HRM M61 Logo
1,157 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
