Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door will not open
Checked outlet for power-lights on motor do not come on. There is a small red button on unit that when you push small light flashes. Gears on unit look in good condition.Keypad outside does not work nor does
inside opener pad. Unit stoped working completely .
  • clarkco2002 May 11, 2010
    small red button is to set up the remotes.....once operator is working again, will probably need to reprogram remotes to work.
    first things first, what maker and model opener do you have. was the door in motion when the opener stopped working
    let me know,
    clarkco
  • 49 Answers
Try pulling emergency rope open door and close it this may reset opener if you have electric eyes make sure they are clear and they line up
Posted on Feb 06, 2009
Raynor garage door motor won't run and won't open the door. It is not sending power to the system despite being plugged in to a working outlet.
More than likely, the transformer in the opener is fried. You need to verify 110V power coming into the transformer, and that there is 24V AC power coning out of the transformer
Oct 03, 2014 | Raynor Garage Doors 4050047 Raynor PEC-R4...
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Jul 16, 2012 | Microwave Ovens
Our garage door is not opening with the wall unit or remotes. When I push the wall unit I hear a click from the ceiling unit. The door operates fine manually. The green light on the ceiling unit (the SRT...
The green light on the motor unit is an LED and random flickering is normal. Your problem is most likely caused by an electrical storm or power surge. You will need to remove the logic board from the motor unit and check for burnt or missing traces on the printed circuit board especially around the small transformer. Your holding that button in will most likely have erased the memory of the unit and all your remotes will need to be programmed once you find your problem. I really suggest you call an technician at this point.
Oct 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 hp garage door opener will go up fine with the push of any button but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the...
If the main light flashes 10 times when the door stops it is a door sensor problem. Make sure the small light on each one is lit and not flickering. If the main light doesn't flash you have either a bad IR sensor which is a small printed circuit board just in front of the motor or you need to increase the down force which is a control on the rear of the motor unit.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster mod 1245R (1999) has indicator lightLiftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink...
The LED flashing 5 times is the code for "RPM sensor or motor overload". Usually if it is the RPM sensor - which is a small printed circuit board just in front of the motor - it will run a few inches and then reverse. I doubt very much it is the motor. I would pull the logic board and check for loose or missing traces on the printed circuit. Especially if you have had any electrical storms or power surges.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open
The light flashing 5 times is the code for RPM sensor or motor overload. The RPM sensor is a small printed circuit board just in front of the motor. I would really doubt it is a motor problem unless you have been operating the opener enough that the thermal overload protector has shut it down. It will start running again as soon as it's cooled off.
May 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pitco fryer sg14R not turn on at all
The hi limit must be tripped. Open the door and find a swich that has a really small red button on it and push it in. If it clicks, it was tripped. If not, with the door open bend way down and look up whare the top of the door is when closed. You will find a small black fuse holder. Push up as you turn, and pull out. Check to see if the fuse is blown, if it is replace with the SAME SIZE & RATING. DO NOT USE TIN FOIL.
Apr 21, 2009 | Kitchen Appliances - Others
6 month old 139.53985dm garage door opener shuts off going down
Unplug unit at power source and check and tighten all connections in the control box. And try this link.
http://www.garagedooropeners.us/technical_information.html
Mike
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
77 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
